59-60 Cadillac disc brake swap?
Discussion in 'The Hokey Ass Message Board' started by ShortBus, Nov 15, 2004.
  1. ShortBus
    ShortBus
    I have a buddy who'd like to put disc brakes on his 60 Cad. He has heard that 68-9ish Cadillac spindles are a straight bolt-on deal and would like to try a set.
    He found some, but the seller won't remove the spindles from the parts car unless he pays for them and won't return his $ if they don't fit. He doesn't want to spend the cash just to find out that they don't fit.
    Has anyone had any experience with this swap? Anyone have advice?
    thanks!
  2. Shortbus: my brother's friend did such a swap on a 60 vert for another friend...I'll see if I can find out what parts they used. I'm pretty sure they were all original Cadillac parts. This is the car:
  3. ShortBus
    ShortBus
    Thanks Peddro!
  4. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    i did that very swap on a 65 deville, worked great and all i had to change was the brake hoses. i think even up to 1976 would work too. i have never looked at a 1960 spindle though so i can't tell you about swaping to a 60.
  5. Fraz
    Fraz
    from Dixon, MO
    Unknown if this is useful info but 59-60 Buicks used some of the same parts as the Cads up front. Maybe you could look for a later Buick to swap disc's from.
  6. ShortBus
    ShortBus
    Thanks you guys. Any info you could get to me would be great.
    viva la HAMB
    Rick
  7. Sorry to take so long Shortbus.....but I've got more info on the way.
    My bro's buddy HASN'T actually completed the conversion (I thought they had).
    Anyway, they're using '71 Caddy discs with Holden Commodore (Pontiac GTO) calipers. Can't say for sure if they're using the '60 stub axles. I think there's a bit a work to do with mounting the calipers yet...
    Will keep you posted with more info as it arrives.
  8. Scrapyard
    Scrapyard
    I did a little research on this when I had my 60. If you have the means to make caliper brakets, disks and bearings from a '76 Deville, 88-91 1500 PU and I want to say it's either 79 or 81 Blazer (can't remember to well on that one though)all fit the stock spindle. You will have to drill a hole or 2 to mount the calipers though.
    This will give you a better idea of what's involved. Click me! HTH.
  9. Crows_59Caddy
    Crows_59Caddy
    from Colorado
    Well I don't know if you got all the info you needed about the swap but I thought I would make it easy for you this place makes a kit to swap them over to Disk breaks its near the bottom of the page and they have alot of other good parts
    http://www.allcads.com/parts.html
    ENJOY!
    Crow
  10. Wicked Tin
    Wicked Tin
    Shortbus, I've been looking for the same thing for my 60. The allcads one is some serious money. I found a place on e-gay that makes the brackets and lists what other parts you will need for a lot less money. He goes by the name Scarebird and makes brackets for a shitload of different cars. Check him out, I think that is the route I am going to go.
  11. Crows_59Caddy
    Crows_59Caddy
    from Colorado
    true that on the having everything part unless they have hundreds of acerage was kinda thinking they may have an idea of parts you may need to do the swap as well or be able to measure out the spindles Im going to be doing the same thing to my 59 here shortly and hoping it gose well also was wondering if anyone knew any place or something that dose the rocker panels and area right aove the skirts for the rear wheels have a little cancer problemany info is great not even sure where I can get the sheet metal ATM
  12. Crows_59Caddy
    Crows_59Caddy
    from Colorado
    Thanks Jeff For the site that may be the best so far that I have seen
  13. here is site for scarebird www.scarebird.com mark will set you up and has great tech support. i have a set of brackets for my 64' belair wagon from him and they are sweet!
