Technical 59 ab fuel line
Discussion in 'The Hokey Ass Message Board' started by set me on fire, May 22, 2024.
  1. set me on fire
    set me on fire
    what size fuel line should I use..I'm considering dual carbs..original line looks like 1/4"
    going to be using stock mechanical fuel pump..not sure if 1/4" will be sufficiant
    thanx
  2. Bandit Billy
    Bandit Billy
    That's probably fine unless you plan on performance upgrades. I plumb 3/8th's (-6AN) on everything. BTW, your garage is disturbingly clean. Makes the rest of us feel bad. :cool:
  3. set me on fire
    set me on fire
    dont feel bad...should have seen it an hour or so before
    thanx Ill go w/ 1/4"
    Bandit Billy likes this.
  4. BJR
    BJR
    I always go 3/8" just in case I decide to change to a bigger engine in the future.
  5. Kiwi 4d
    Kiwi 4d
    I am a in the middle man , 5/16 every time on vintage engines from tank to carbs. 1/4” possibly on short lengths like fuel block to carbs , but again I have never used 1/4”
    19Eddy30 likes this.
