59 chevy guys...I need your help. I have a 59 2 dr sedan that I want to build and it is need of front and back windows. Today I found three 60 chevy 4 drs. Will the front and back glass fit my 59?
The windshield is the same for all 59-60 GM sedan bodys. I think the rear glass is the same between 2-4door sedan but I suggest measuring it to be certain.
To expand a bit, 59-60 GM sedan, station wagon and El Camiono use the same windshield. Convertibles and hardtops use the same and is basically a shorter version of the sedan windshield. I believe the sedan (not hardtop) rear windows are all the same, but as advised measure first.
The windshields and rear windows from a 59 and 60 Chevy sedan, either 2 door or 4 door, will interchange. I used a windshield and rear window out of a 1960 Biscayne 4 door sedan in my 1959 BelAir 2 door sedan. As mentioned, the hardtops are different from the sedans.
SEDAN = Post ! but there was also a 62 series Caddy that is actually both... It uses a GM sedan windshield and roof line but had hardtop windows.
