Projects 59 chevy wagon in progress
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Mar 23, 2010.
  1. TexasSpeed
    TexasSpeed
    from Texas
    I feel the same way. There are few people here who understand my vision. Especially friends and family-wise.
    But on here, I know everyone will.
    Your '59 is drop-dead gorgeous. Period. And if anyone thinks otherwise, it's because they don't have taste.
    This build ranks up there with the best HAMB builds, IMHO.
  2. oldman2
    oldman2
    Just caught this thread today, you are doing some amazing stuff, just great work, I have subscribed and can't wait to see more pics.
  3. nice fab work! what kind of wheels are you gonna run?
  4. olpaul
    olpaul
    Very cool. A great looking wagon! Is the engine a 292? I raced a 250 six back in the day.
  5. Ricky B
    Ricky B
    Freakin' awesome ride !!!!!!!
  6. Cody Walls
    Cody Walls
    So somemore updates , I got the chance so spend a lot extra time on the wagon these past couple of days I know it might not seem like I got alot accomplished from the pictures but I did .
    So I finished the headers as far as I need to go as for the mock up stage.
    I ended up just welding the two muffler together since I'm running the duels exhaust on the driver side also I'm using v band clamps instead of regular flanges and gaskets .
    Just trying to keep everthing tuck up tight and nothing hanging below the frame
    Just go's to show u I'm running out of room quick on the driver side
  7. Dirt Diggler
    Dirt Diggler
    even your mufflers look trick! thats it, this car needs to go into a museum when it's done. :p
  8. Nads
    Nads
    from Hypocrisy
    I'm beyond impressed, I'm blown away.
  9. Cody Walls
    Cody Walls
    thanks man
    thanks also and i just posted more pics:D
    thanks, im running thoes wheels , and hubcaps , im still kinda up in the air on which hub cap im going to run .
    thanks and yes the motor is a 292 . :D
  10. ratster
    ratster
    wow what a build, nice work
  11. Cody Walls
    Cody Walls
    Thanks man , this car is screaming to be driven and its going to be driven hard :D untill the wheels fall off :eek:.
  12. reaper71
    reaper71
    Well you won't have far to go if they do fall off!!! lmao:D
    Really nice build BTW
    Mark
  13. aw1950
    aw1950
    Very impressive work . And your how old ??? I better go back to the drawing board . I'm doin something wrong LOL !! Stay at er!
  14. W:eek:W! just found this build, very motivating! subscribed and cant wait to see more
  15. rusty76
    rusty76
    from Midway NC
    This thing is really comming together. Cool man.
  16. Cody Walls
    Cody Walls
    Thank you , and yes i just turned 27 in jan ,:D
    lmao too
    Thanks
    yes it is, just not as fast as i would like at time :(
  17. wolfex1
    wolfex1
    Hey Cody, take a vacation and get her rollin. Spring is just around the corner. ~WX1
  18. Cody Walls
    Cody Walls
    I wish I could Chris , but if I did that I don't think it would ever get finished :D
  19. Cody Walls
    Cody Walls
    So today again I got a lot done but not a lot of pictures showing progress , latley my focus has been to get the final mock up of everthing on the motor done and hopefully in a few weeks it will be ready to be pull and brought home so that the block can be smooth out at night time.
    I had to notched the frame for the other exhaust pipe to go threw so that it didn't hang down below the frame.
    And to the clutch arm which is on the p*** side ,when engaged it was hitting the floor pan.so somemore things had to be cut up.
  20. wolfex1
    wolfex1
    That bell housing/clutch out of a truck? Mine was out of a '61. I tried using the stock slave cylinder, but the clutch master that came with my new pedal ***y. didn't have enough juice to push it all the way out. I ended up using a jap slave cylinder. Make sure the bore matches on both, whatever you use. ~WX1
  21. maddog1949
    maddog1949
    you are doing some great work. love the wagon
  22. Cody Walls
    Cody Walls
    Thank u:D
  23. My Dad always emphasized, keeping the exhaust above the frame. ****ty exhaust, hanging down under a car, quickly deteriorates the look and overall question of the cars true craftsmanship. Beautiful work, Woody!!!
  24. Cool_Junk
    Cool_Junk
    Love it man! Makes me want to finish my 59 Sedan Delivery. I'm a big fan of the 59 fins!
    Drew
  25. Toner283
    Toner283
    You need to post up a pic or two of that delivery.
  26. hemifarris
    hemifarris
    3 of my favorite threads belong to WOODPECKER", "J.Fishbeck" and "Nads". I'm becoming partial to these '59s..........................Oh yeah, I also like the one started by hemifarris regarding his '59 El Camino. :)
  27. Cody Walls
    Cody Walls
    Well here is what I got done today ,since the motor is set back and there not much room to get the valve cover on and off easy, I had to ither remover the water neck housing in the process or cut into the cowl area , and I fugared it would be easyer if I was out on the road to remove the cowl p****.
    And make it a bolt in piece
    I also had to space out the water neck 1/2 inch to clear the valve cover
    . And after all of that it was finally time for the motor to come out .
  28. reaper71
    reaper71
    Moving along nicely!!!
  29. wolfex1
    wolfex1
    Hey Cody, how about a picture or three of that valve cover adaptor you are teasing us with just a corner of? Maybe one of it bolted to the head. Is it bought or made by you? Also, what is that trans? 5 speed? out of what? does it have a lower first gear or overdrive? Also, what starter and flywheel are you using? ~WX1
  30. Ricky B
    Ricky B
    Cool wagon bomb !!! :D
