Projects 59 chrysler newyorker custom build
Discussion in 'The Hokey Ass Message Board' started by tattoos by brandon, Sep 15, 2011.
  1. George
    George
    Not sure if there's any difference between '59 &, say, a '70 starter, but the SB & BB starters for the 70s interchange with the SB one being a little shorter. I use a BB starter on my SB 727/ 331 combo.
  2. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I believe the issue is that the Torque converter has the gears on it. I had to use my 413 crank and a 440 block to bolt up to that converter so I can use my transmission it's the push****on torque flight or something
  3. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I was liking earlier and this is what they have I gotta call them but it might work [​IMG][​IMG][​IMG]
  4. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG]. It looks like it's the same transmission from the things I'm seeing online. I'm going to jump on the forward look when I get home and see if anyone has replied and thank you all very much for the info it's keeping me positive about the car and it's hard to keep going when there are these confusing issues and with all the money I have into a 4 door haha but it will get there
  5. 73RR
    73RR
    Sanderson has a reputation for headers not always being 'perfect' and some that need some work on a particular application. It may be that you will need to modify what they send to you. Ask Herman what he did.
  6. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Yeah I had a set of the block huggers that didn't fit and they gave me **** about returning them and I sent him a message and a comment on the post. Nothing back yet
  7. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I lied he messaged me back telling me there is only one set and I'm currently talking to him about the issue I might have so hopefully I will order a set Monday and get back on track
  8. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG] me and my friend got some stuff done and some of the bad patch work cut out
  9. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Good new so far the steering box should be here tomorrow and the rear quarter on the driver side is almost done we were able to cut out and salvage some of the patches and work with what is there... We had to heat and push out the dent's and cool them because the whole rear was weak from all the warping but so far so good should have pics tomorrow but in the bad new I can't find a mini starter to use the headers I want so my opinions are some stock manifolds and drill the head and tap it to mount my alternator or???? Still looking for other options
  10. 73RR
    73RR
    1. You are knee deep in sheetmetal repair. Why are you reluctant to modify the headers?
    2. ...probably easier to replace the heads with post-62 pieces.
  11. tattoos by brandon
    tattoos by brandon
    from salem ohio
    That's true and I already cut up a pair of headman full size headers and still couldn't get them to work I guess I could buy the cheaper versions of the shorty ones and try to make it work but there is not much room to work with how the starter and steering box is set up and I can do sheet metal i just don't feel as confident with making exhaust... I even thought about trying to find a place that can make me some but can't seem to find anything close
  12. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG] Monday I go and pick up the 37 Plymouth coupe so hopefully I can get the 59 going soon so I can work on getting This out this year also
  13. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I also picked up this 59 lark [​IMG]
  14. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG] [​IMG]
    Got the hood hinges powder coated in a chrome look and also did the braces for the engine bay ... The springs will be black
  15. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG][​IMG] [​IMG][​IMG][​IMG][​IMG][​IMG] well today we productive..I helped a friend work on a truck he is doing to get caught back up and he let me take the old body that was in the s**** pile and a deck lid ...I couldn't see this getting s****ped haha but I got most of the rear quarter on the driver side straight and re patched I didn't get picks but here are some of my friends yard and the new tool I made to make fixing the rear quarters easier with what I had
  16. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Well I have been working on the lead work on the 52 but I decided to round the hood corners of the 59 so I started by cutting along the outside edge and then cut from the back side middle to the cut I run along side the out side of the hood ...then took a hammer and dolly and boom done just gotta weld it up and grind it smooth
  17. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG]this was under one of the half *** patched that we put right over the bad metal not even any effort to cut out the old [​IMG]i could t get a good picture because of where I set my hood but it's slowly getting there and I fixed a lot of the issues with the ****ty patch work but still a lot more to go [​IMG]welded up and ground done the corners of the hood and just put some spray can paint on it to avoid rust
  18. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Well I've tried a few manifolds and all the headers I could find but nothing cleared anything hahah ..I want block huggers but they hit my a arm so we are going to try to mod them with tubs from my other headers.... I need a center dump for the drivers side and p***engers side has all the room in the world [​IMG][​IMG]
  19. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I'm having the block huggers modified and should be ready in a few days and I got the rear end back in alinement for the most part ...also got the hood hinges back from powder coat ...ill take pics and post them soon
  20. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG]drivers side clears just the p***enger side needs some tlc to fit [​IMG]
    [​IMG] I still want to cut the bag mounts off and re mount them to get a better alinement at ride hight but I'm happy with it for now
  21. tattoos by brandon
    tattoos by brandon
    from salem ohio
    [​IMG][​IMG][​IMG]
    Update
    Car runs and drives and stops good finally!! Still got a few things to work out but new headers after modifications work great and we figured out all the wiring ...divers side rear quarter is fixed and body work started and oh man do I hate these huge straight quarts and so do my arms haha ... had to take the neutral safety switch out and line of the linkage centered while in ****on was in neutral...worked great! But remember to drain the fluid haha ...brakes now that's a story.. the whole time I thought there was air in the system and after putting in a residual valve and nothing changed I found out the pedal ratio was off by ...a lot haha so I changed that and adjusted the pedal and the adjustment between the master and booster and now they are almost perfect just some more tweaking to do and have to replace my cap because it won't seal and I'm done messing with it ...p***enger side quarter is almost done with hammering then body work on that side ...I'm thinking about doing something custom for rear and front bumper so that's next after I get her on the road and some things worked out
  22. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Some before after [​IMG][​IMG]
    She's not beautiful but I had to take her out for at city's big car show this weekend and man it's nice and is getting me motivated
  23. choptop40
    choptop40
    Ugly duckling..love those crazy lines.....
    tattoos by brandon likes this.
  24. Good work sir . I love everything about the vehicle ( hey, what's not to love?) . The bodywork is outstanding and well, the stance is just right. Once again, good work.
  25. Racingsnake
    Racingsnake
    from So Cal
    Just found this thread and read the whole thing, lots of cool work going on and the car is looking great!
    Was interested to see the stepped lower arms as I'm in the middle of doing something similar with my '62 Imperial, although I'm keeping the torsion bars. Despite the Imperial having a full frame and the Chryslers being unibody it looks like the front suspension is very similar so I'm wondering if the Hedman shortys may fit with a bit of work - does anyone know the distance between the torsion bars on the Chryslers so I can check if the Imperial is the same?
  26. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Thanks
  27. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Thanks. Man it’s been a challenge but a good learning experience...the 52 im building the wife is coming out nice also but I got through a lot of the mistake making with the 59 haha so the 52 seems like a simple thing
  28. tattoos by brandon
    tattoos by brandon
    from salem ohio
    I’ll try to get pics soon an post it and unfortunately don’t know the measurements but I believe chrysler and imperial shared frames for most years
  29. tattoos by brandon
    tattoos by brandon
    from salem ohio
    So I have been buying more cars haha got a cabriolet and a 32 five window last week
  30. tattoos by brandon
    tattoos by brandon
    from salem ohio
    IMG_7333.jpg I’m currently trying to find a replacement bushing for the steering rod where it bolts into the steering box anyone got any ideas of where I can find one and or what it is and or options that I can do if I can’t find anything ?
