59 edsel
Discussion in 'The Hokey Ass Message Board' started by 067chevy, Dec 17, 2005.
  1. 067chevy
    067chevy
    :confused: what size engine came in 1959 edsel villager wadon and what about rear axle 9" ? I picked up the car today was a freebe but my buddy wants to cut roof of for his 34 two door sedan. The car is complete but alot of parts have been taken off. They are all in the back end of car. thinking of parting out but will probably keep motor and trans. love that that horse collar grill. I already hung it on the wall in my shop
  2. Just Gary
    Just Gary
    According to my '64 Motor's repair manual, the '59 Edsel came with your choice of:
    CID/ carb/ HP/ Torque
    223 (6)/ 1 bbl / 145/ 206 lb-ft
    292 V8/ 2 bbl/ 200/ 285
    332 V8/ 2 bbl/ 225/ 325
    361 V8/ 4bbl/ 303/ 390
    Sorry, I can't help with the rear axle.
  3. Little_E
    Little_E
    Edsel.com says standard for the villager is the Express V8 332 cid, but it also depends on the VIN, I believe the first letter on the dataplate gives engine code.. Here are what the VINs mean for engines:
    A = 223 in line 6 (economy six)
    C = 292 V8 (ranger)
    B = 332 V8 (express)
    W = 361 V8 (super-express)
    www.edsel.com is an incredible resource to learn more about the car!!!
    P.S. Here are the axle ratios based on VIN, but I'm not sure which order on the VIN these come. I don't know if this is what you are looking for on the axles or not.
    VIN Code 1: 3.10 : 1
    VIN Code 2: 3.56 : 1
    VIN Code 3: 3.70 : 1
    VIN Code 4: 3.89 : 1
    VIN Code 5: 2.91 : 1
    VIN Code 6: 2.69 : 1
  4. WQ59B
    WQ59B
    Edsel VINs do not contain axle coding; they are on a lower line of the dataplate.
    This '58 Edsel plate tells the following on the 2nd line:
    "AAA" : Jet Black body/ roof/ rims
    "AA" : interior trim code
    "17J" : 17th of September (build date)
    "4" : transmission code
    "A" : axle code
    On a '59 plate, the axle code is in the same spot, but uses the code numbers Little E posted above.
  5. Chuck_S
    Chuck_S
    Many parts on the 59 Edsel interchange with a 59 Ford. The rear axle is a 9" and from what I understand is the same width as the 57 - 59 Fords. -- Chuck
  6. TexasDeuce
    TexasDeuce
    what parts are you gonna get rid of? got any pics? lemme know when you are ready to get rid of parts....
    thanks, TD
