Projects 59 El Camino.. Part Two
Discussion in 'The Hokey Ass Message Board' started by J.Fishbeck, Nov 10, 2011.
  1. Cody Walls
    Cody Walls
    Cool I can't wait to see the outcome
  2. The media blaster showed up today. Along with the gl*** beads. I need to find a place in the I.E, that sells the gl*** beads. Tomorrow, I'll get everything tefloned and ****oned up. Finally!
  3. slammed
    slammed
    Righteous score JJ. I rent one from a dude from town here (mostly blast his stuff and use free) what dud this set run fer $?
  4. 4 Hundy.. It'll pay for itself just in the next few jobs. I'm stoked on this thing!
  5. The weather was gray.. '****' it was still a great show
    This 2dr stood out, a****st the only 4drs I would never consider as just parts cars!
    15W Bus.. A deluxe with the corner gl***. Yes
    Coles Nomad
    I think a 58 Cad rr bmpr will look good on my 57BelAir
    Customizing a 57 Pontiac rr bmpr would be different. Fill in the top, where it dips for the plate.
    I like the look
    Like my friend Trista said, Mucho Trubajo!
    Bootiful!
    Brite white pinstripe, over cream
    Another cool rear bumper!
  6. I'm a ****er for pearls
    Taint Pink
    Amazing
  7. Yesterday I set everything up. Then I go to figure out how this blaster works.. only to be shut down. Ends up being a .25cent 10/32 fine thread fix.. Fudge! Why would this ball valve have this extra outlet? That question repeated in my wittle bwain, repeatedly!
    Didn't touch the fibergl*** resin
    I'm really happy (stoked) with how rad this blaster and the gl*** beads remove the most stubborn of MO. rust!!
    Now, I have to figure out how to sift all this clean again.
  8. El Caballo
    El Caballo
    from Houston TX
    Is this your version of safe ***?
  9. Numb **** safe *** would be better than this ****, anyday!!
  10. slammed
    slammed
    Very fine screen's from windows will do it fer ya JJ!
  11. You know what.. I'm on my way to the hardware store, now! That'll work!
  12. treb11
    treb11
    and a magnet to grab the fines that p*** through
  13. That's good info, right there! Appreciate it
  14. strike a poser
    strike a poser
    from Salinas,CA
    That little screw hole in the valve is to bleed the air from the line down stream from the valve when it is closed. It's a safety thing, probably not needed in your application.
  15. There's no info on it, in the paperwork they sent. My uncle said the samething. Should've been some sort of bleeder valve.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    As already stated, this findings is from McMaster-Carr
    Safety Air-Exhaust Br*** Ball Valves
    Meet OSHA requirements for safety and control in your compressed air system. When closed, these valves vent air pressure through the exhaust port on the bottom so you can disconnect air tools safely.
    http://www.mcmaster.com/#ball-valves/=lb1zya
    Now, since there's no info from that link either. Does it bleed air with the valve closed with air connected from the compressor in that configuration? What if you mounted the valve 180 of what it is now. Then it may keep full pressure when open and bleed off only the blasting tank and not bleed off air from the compressor when the valve is closed.
  17. Not when it's closed, just when it's open. I need to be patient and wait for customer service to answer. I'm curious what they have, that fits there.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That don't sound right either. Will just wait and see then. But here's a thought. What if the handle was installed 180 off at the factory that made the valve? Try removing handle and turn the ball 180 and re install handle. Give it a shot and that don't work, I say the valve is faulty.
  19. I'll post a better picture tomorrow, of the set up.
  20. Should go a little quicker with the paint gone, when I next blast the rest.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Check Check, One Two, Check. It's working. Too much Football action for Jay I guess. I'll give him another 24 Hrs before I send the troops out.
  22. I just finished blasting for the day. Now I have to vacuum up the gl***, again. Pic will follow
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
  24. Was it real or memorex..
    Tedious work, but I do like the results. I felt the panel after I hit it, an it was warm. Nothing to worry about as long as I keep things moving along. FUN-FUN
  25. slammed
    slammed
    Envision a 'funnel' for the walls of your blast area. So it flows in a controlled manner to the immediate ground. Having a helper with a drop light, check your work immediately as you go to save you time, with these bigger pieces.
  26. As soon as the sun went down, the blasting hood started fogging up. Added to the frustration of the whole thing, for sure. A funneled floor with a vacuum recovering system would be great. With a filter to clean it as it collects.. leaving it ready for immediate use. Yeah, I could imagine that in my dream shop!
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Then get a Wonka Vision Blast Cabinet. Say you don't have space, no problem. Damp evening's, a problem of the past. So order your's now!!!!!
    And for the first 10 caller's, a free Wonka Blast Suit as seen in this Add
    Call right now and talk to Jennie. Here's the number to call
    1-800-867-5309
  28. The old lady Jenny that answered the phone, wasn't stoked that I called.
    Couldn't believe this was playing in the background, either
    <iframe width="640" height="360" src="http://www.youtube.com/embed/Rq43RWeV7FA?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Try that same number with a 900 area code ;):D
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    All fun aside, what did you find out on that Ball Valve issue?
