Technical 59 f100;428 conversion
Discussion in 'Traditional Hot Rods' started by Jimhavins, May 18, 2025.
Tags:
  1. Jimhavins
    Jimhavins
    Have 59 f100 custom cab in parts (my old truck) a c6 that needs to be refreshed,a 410 mercury Marauder bored to stock 428, solid cam, out of my other old truck.
    I have heard there are clearance issues with the 428’s oil pan, does anyone know if there is a aftermarket pan to solve the problem, not a 4 quart pan
    Tow Truck Tom likes this.
  2. IMG_6442.jpeg Will a 4x4 pan for a 390 work
  3. Jimhavins
    Jimhavins
    That’s the problem. I don’t know what will work.
  4. Jimhavins
    Jimhavins
    It looks like it will take a different oil pump pickup, maybe a different pump
  5. Jimhavins
    Jimhavins
    Do you have the 390 pan?
  6. FrozenMerc
    FrozenMerc
    Canton makes a real nice copy of the FE 4WD truck pan. I just ordered one and installed it on the FE going in a 1960 T-Bird with a Cro** Vi* front suspension. Fit like a glove and holds 7 quarts. Make sure to order the rear sump pickup tube and the mounting stud for it as well.
    https://www.cantonracingproducts.co...8-fe-ford-deep-rear-sump-truck-oil-pan-black/
    That is the joy of hotrodding! Sometimes you just have to buy some parts and see what you can piece together and make work. That, and Canton (and many others) have dimensions on their website, so you can always make a cardboard cutout and give it a try before ordering.
    deathrowdave, Budget36 and Boneyard51 like this.
  7. flatout51
    flatout51
    It will work. It uses stock pump different pickup. They are pricey. I have one on my 390 I put in my shoebox. I have a 60 f100 4x4 with a 289 with a 4x4 pan. It clears perfectly and I had the 289 in my shoebox at one point. Find a 4x4 pan and be done.
  8. Cut the pan and flip it
    Seen a guy here weld bbc pan to create a rear sump pan
    Fab the pickup tube
    deathrowdave and Budget36 like this.
  9. Jimhavins
    Jimhavins
    Thank you very much, and just like that, I’m on my way
  10. Jimhavins
    Jimhavins
    Many thanks
  11. Jimhavins
    Jimhavins
    Many thanks
  12. Nearly 60 years ago I helped a buddy swap a FE into his '59 Ford panel truck. IIRC he used one of those 'universal' FE swap crossmembers that you can still get for the front mounts and slightly reworked the rear crossmember. The front sump pan cleared easily. But this ***umes you're sticking with the stock front suspension; if you're swapping to an IFS or drastically lowering it, all bets are off. Ford used front sump pans on all 2WD pickups from '65 (when the FE were first installed) to the end of production in '76. Only the 4WD got the rear sump pan.
    As far as pan size, the front sump pans were all pretty much the same. The HiPo versions got better baffling and Ford would vary the amount of oil from 4 quarts to 5 depending on the application in the same size pan.
    If you use a Ford 4WD pan, do yourself a favor and braze the dipstick fitting to the pan. They tend to leak around the gasket.
    Truckdoctor Andy and Budget36 like this.
  13. bobss396
    bobss396
    I helped a buddy put a 352 into a '56 F100 in 1978.
    He ordered a Trans Dapt kit that came with mounts and a tubular cross member. No welding, we drilled holes and bolted it in.
  14. deathrowdave
    deathrowdave
    from NKy
    My Buds stock 66 pickup with stock 390 pan just barely clears the stock front cross member . When I say barely it’s about 1/2 inch . He has had 3 of these trucks so far and never one issue of pan contacting the cross member , but it’s scary close to me .
