Technical 59 Mercury flathead
Discussion in 'The Hokey Ass Message Board' started by bob giles, Mar 27, 2014.
  1. bob giles
    bob giles
    trying to use all the parts. Does #1 fit in #2 and sit in the block before the intake is installed?
  2. Bruce Lancaster
    Bruce Lancaster
    Part 1 goes into a socket on the underside of the FP stand, flange on part 2 is sandwiched between the stand and the manifold in a little recess you will see. There is something deeply wrong with the umbrella on the FP pushrod. Engine looks nice!
  3. bob giles
    bob giles
    Flange on push rod is moveable. Where does it belong?
    Thanks
  4. Bruce Lancaster
    Bruce Lancaster
    Open side points down toward block and it sits just a little above the iron at the bottom when it is in place. You will probably find some marks or scars on the pushrod about 2" from the end opposite to where it is in the pic.
  5. bob giles
    bob giles
    Thanks, I see where it belongs
