Technical 59 Ranchero Windsor swap runs hot- what have you done- update bad Chinese temp gauge verified.
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Dec 14, 2022.
  1. BamaMav
    BamaMav
    from Berry, AL
    The ones I’ve seen marked front it was because of the offset of the center hub. Some have more offset than others.
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Eric;
    If you do go to a shroud, the correct position for fan blades is 1/3 in, & 2/3 out. Half in/half out is ok, but it works better to do it the way Thermo King specs for their condenser shrouds. I had to do a fair amount of repositioning the condenser fan blades correctly over the last 25+yrs, when they didn't cool properly, due to guys not understanding or comprehending this. Or being just lazy. If no shroud, get the fan blades w/in an inch. Odd # of fan blades is good, but avoid flex fans like the plague they are. Oem are usually good too. Me, I rather like the clutch-fans in shrouds, but they are heavy & not "pretty/flashy". Every little bit helps.
    FWIW.
    Marcus...
    bobss396 likes this.
  3. aussie57wag
    aussie57wag
    from australia
    If you upgrade to a y-block you will fix that issue and it will go better and be better.
    warbird1 likes this.
  4. 327Eric
    327Eric
    I had to come up this weekend to repair storm damage, the carports for my Ranchero and Henry J were destroyed, the cars weren't hurt, and got to revisit this as I had to fire up the 59 and pull her out. After warming it up and watching the temp gauge move faster than seemed right, I pulled out grandmas old meat thermometer, and stuck it in the radiator, and as the temp gauge danced and climbed, the old meat thermometer stayed at a steady 180. I am not happy with the airflow through the radiator, and will upgrade the fan and build a shroud, it seems all the problems were related to poor quality gauges and a faulty( read cheap) infrared tool. The P..O. installed a Bosch gauge panel from Summit, which I will be upgrading as well
