Technical 59A flathead cooling system
Discussion in 'Traditional Hot Rods' started by 65standard, Jan 7, 2024.
  1. 65standard
    65standard
    Does the 59AB ford flathead need two temperature gauges? Or is the radiator the common reservoir tying both sides of the motor together?
    Thanks, Tony.
  2. Bandit Billy
    Bandit Billy
  3. 65standard
    65standard
    Thanks for the help.
  4. alchemy
    alchemy
    I only have one.
  5. Bandit Billy
    Bandit Billy
    I have 2 on my 8BA, the heads read completely different temps. I don't know, do 59A have 2 thermostats? If so, wouldn't they need 2 temp senders?
    Center of the Galaxie likes this.
  6. The radiator is the only place where the coolants from each side of the engine can mix together. Each side of the engine has a separate cooling system from each other. Although the Ford cars only had one temperature gauge, they did have a temperature sensing device in each bank. The sensor on the left bank worked the gauge while the one on the right only worked the gauge if that side overheated. It would then peg the gauge to tell you something was wrong. I have only used the one sensor on the left side and it has never been a problem I think the coolant mixes enough in the radiator to minimize minor differences.
    acme30 and Bandit Billy like this.
  7. Yup, my 8BA shows somewhat different temps side to side. To accurately monitor engine temperature, a gauge on each side is required. Ford's factory system with a gauge for one side and a "hot indicator" for the other was just fine. If you don't monitor both sides and a thermostat sticks shut, a gauge in only one side may not tell the tale. Same for 59As.
    The 39 guy and Bandit Billy like this.
  8. acme30
    acme30
    from Australia
    I did not know this but it certainly makes sense now you have explained it.
    Following on from your knowledge and understanding ............. can the stock sensor from the right side be used to connect somehow to a "modern sensor" on the left side? I am curious as I just run one cl***ic instrument sensor and gauge on the left side head and nothing on the right at this point.
    On my 8BA flatty the left side runs 20 degrees hotter than the right so I figured that would be where I put the sensor - ( I reasoned rightly or wrongly that if the right did ever get hotter than the left then it would eventually also show up in the left side via an overall increase in coolant temperature from the radiator.
  9. Bandit Billy
    Bandit Billy
    I have seen people run a toggle switch to chose which head the gauge monitors. I chose to run two temp gauges in lieu of a volt gauge. So far that was a good idea...:cool:
    Toms Dogs likes this.
  10. I have in the past, using just one electric gauge, put a sending unit in each head and a switch to change which side the gauge is reading. You have to remember to switch from side to side when you are checking your gauges though. I prefer to use 2 gauges but that isn't always an option.
  11. Bandit Billy beat me to that answer by a couple of minutes. :)
  12. acme30
    acme30
    from Australia
    Thanks guys it would be my luck that in times of need I would always have the wrong one showing!
  13. Ziggster
    Ziggster
    Good info. Just another flathead fact to keep I the back of your head.
  14. I run two gauges as well, there's nothing wrong with that. Like others have said each side of the engine runs at a slightly different temperature and it's nice to have a side by side comparison.
  15. BJR
    BJR
    Has anyone ever figured out why the left side always runs hotter than the right? It really makes no sense since both sides are a mirror image of the other.
  16. alchemy
    alchemy
    The left side of the car has more weight. The driver is always there, as well as steering and brake apparatus. So the left side has to do more work. Hence the higher temp.
    NoSurf likes this.
  17. Jeff34
    Jeff34
    I run a switch and one gauge in my '34. Works fine. For some reason, the right side runs a bit cooler than the left.
  18. Bandit Billy
    Bandit Billy
    I went with two gauges (SW hencho en Mexico) that don't read all that accurate but they look nice in the cluster. I have tested with a IR and they are off by 15-20 degrees. I don't have any overheating issues so I don't worry about it.
  19. Model A Gomez
    Model A Gomez
    I've only ever ran a single temperature gauge on my flatheads since in the 60's without a problem but have noticed the right bank is always 10-15 degrees warmer than the left bank with my hand held IR on the flathead in my coupe. Hadn't thought about replacing the voltage gauge with the second gauge on my 5 gauge cluster.
  20. 38bill
    38bill
    from Minnesota
    When I built my truck with a 59AB I ran two temp gauges below the dash. The p***enger side always ran slightly less than 10 deg higher than the drivers side. When I rebuilt the original gauge cluster I went with a single temp gauge and sender. My flathead actually runs a little cool so for me its not really a issue. Two senders with a switch running a single gauge would work if your worried about it.
  21. Zax
    Zax
    I run the stock, which is in the left head, and an aftermarket S&W mechanical in the right head. Seems to work okay for me.
  22. tubman
    tubman
    Here is my standard response this question : WM-DUALTP.jpg
    sdluck and Bandit Billy like this.
  23. The 39 guy
    The 39 guy
    I have been using the one gauge two sensor system for a few years now in 59L engine. Works fine, I just have to remember to use the switch. I usually don't worry about switching until I notice the temperature climbing on a hill.
  24. mister moustash
    mister moustash
    from new york
  25. mister moustash
    mister moustash
    from new york
    I ran the auto temp switch on my 41 flatty came on at 175 kept running till temp came down to 180 what difference speedway kit easy install
    acme30 likes this.
  26. The 39 guy
    The 39 guy
    I have a temperature auto switch also but I usually leave the fan on all summer. In the fall I switch it back to auto. My flathead doesn't really run hot I am just supper cautious as flatheads are generally famous for overheating and I don't want to over heat the engine and crack my block.
  27. joel
    joel
    I made my own `gauge panel insert and barely squeezed in the speedometer plus 4 of the usual small gauges. I have 2 temperature senders and a switch to one gauge as several have described. The 2 sending units have different resistance readings so they will not read the same. The sending units ( at room temp) are within 1 ohm of each other when disconnected from the gauge. They read within .8 ohm of each other when the switched to the gauge. IIRC, with the engine warmed up, the p***. side was about 10 deg hotter than the drivers side. When I switch from one side to the other, it takes maybe 15 seconds for the gauge to " catch up ".
    acme30 likes this.
