59AB backfire trouble
Discussion in 'The Hokey Ass Message Board' started by Django, Sep 29, 2009.
  1. Django
    Django
    from Chicago
    So in our '36 4 door, we have a sick flatty and we're trying to get it roadworthy for a wedding next weekend. Seems like it is only running on 7 cylinders and on that dead cylinder, the exhaust valve acts like its stuck, but it would run fine considering. But now it keeps backfiring if it starts and blowing out the dipstick tube.
    Did it jump timing or something? Any suggestions??
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    do you have a hole in the piston?
    maybe there is gas getting into the oil pan and igniting causing the dipstick to blow out- I had a breather do that and bounced off the hood and shot clear across the shop- but the car was flooded really really bad...
    just a thought...
    sorry man that ****s.
    Tuck
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    do a leak down on the cyl in question- but make sure you dont screw one in too far if its long because you can break the valve off... ask me how I know... haha.
  4. Django
    Django
    from Chicago
    I think you are right, unfortunately. The breather cap was hot and smoke was coming out the tube. Damn, we were so close too. Guess my cousin will have to take my coupe instead.
  5. Django
    Django
    from Chicago
    Upon further inspection... the piston is completely GONE! Holy ****!!!
  6. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    woah- broken rod and it dropped in the pan?
    thats crazy...
  7. Django
    Django
    from Chicago
    Check this out!
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Yikes. Thats scary.... I sure hope it didn't cause too much damage.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    whew... easy fix...
    just hone it out and drop in a used piston-
    I dont see any deep grooves up high you might be able to roll without haing to rebuild the whole thing...
  10. Mike51Merc
    Mike51Merc
    That's nasty. Nobody heard it happen? Just pull the rod and lifters out on that cylinder and keep drivin'.
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    Don't think the lack of a rod will affect oil pressure, do you?
  12. R Pope
    R Pope
    If the walls are good, you could try slipping another slug in it. Pull the other head off, though, and check for schrapnel that may have ****ed through the intake to other cylinders. It'll probably need a full overhaul later, but you could get it running quickly if you want. All that **** had to go somewhere!
  13. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    the only place that stuff couldve gone is the oil pan...
    The only thing I would pull is the pan, clean it out, and I'd put a new piston in there- the rods good- leave the same rod bearing etc-
    If you need one I might have one Chad- lemme know-
    Tuck
  14. Ace Brown
    Ace Brown
    from OH
    Holy **** chad that's the craziest thing i've ever seen!
  15. Django
    Django
    from Chicago
    Yeah, I could use a piston for sure! Thanks.
  16. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Chad I got you covered... as long as that block isnt overbore... PM me you addy I can mail it- or I'll bring it to the hunnert.
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    You're lucky.
    I wish I had pics... I cracked a piston in my caddy convert...
    I had a girl with on a date, on the way back from the movies when it let go... and I decided to push it to see how far I could get. Kinda Dumb.
    Well... I could've drove it home- probably... we decided instead to drive it to her grandparents house... - the rod and pin made this deep gouge in the cyl wall to the point where it needed to be sleeved. If I would've shut her down right away I bet I could've put a new piston in it and have been back on the road... before it started to sound like a hammer rapping around in a pipe... dammit.
    Engines rule...
  19. 55 dude
    55 dude
    tuck, did ya get laid?
  20. Hellfish
    Hellfish
    Next weekend?! What's with all your friends and family always wanting to get hitched on Pileup weekend?!?!
    That ****s about the engine
  21. Kiwi 4d
    Kiwi 4d
    Takes a while to get the sump off etc. Ford never designed it well. Take off radiator hoses and stay rods, starter, headers, lift up motor to clear crossmember to allow you to lower sump. Get a slick back greaser hair do. slap in another slug ,if you are licky your bearings will be ok. What were the pistons in your motor? Me unless I had plenty of time I would leave it and use your coupe and take my time later after the wedding and fix it properly, so wont need to worry about one dodgey slug in the future.
  22. Mike51Merc
    Mike51Merc
    I was joking!
  23. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    55 dude... haha yeah but thats another story... :p
    I take back that earlier crit on parts getting to the otherside...
    -apparently it can happen, just got off the phone with another flathead fanatic that found a broken piece of valve guide from one side of the engine in a Cly on the other side of the engine. hmmm...
    I would think you would break a valve off pushing something around in there but "maybe" not... so prob wouldn't be a bad idea since you have to buy head gasket(s) anyways...
    The piston I have is out of a early block- should be the same. I'm sending the rod and all- I think it still has the rings on it.
    Good luck :)
  24. Django
    Django
    from Chicago
    update: My Dad and cousin took the '37 flathead out of my ch***is for my cabriolet, threw it into the 4 door and it fired right up, so they are good for the wedding again. :D :cool:
