59AB Flathead motor that was pulled out of a 34 ford. Good running motor & did a compression check on 8 cylinders & all cylinders were good. Block was cleaned & painted red with gun metal grey paint on the cast finned heads. These heads are Kogel Cast Iron Finned heads which are rare. New rebuilt distributor & plug wires. Also new spark plugs. Resurfaced flywheel, new clutch disc (91-7550 9 in.). Also new pressure plate. New Tattersfield PM-8 intake manifold with old chrome 97,s (need rebuilding). Two new cast aluminum tattersfield custom air cleaners. Water pumps are new & new Powermaster torque starter. Been turned over every month. This is quite a setup for your hot rod. 7k obo.
