Technical 59AB Flathead thermostat stabilizer ring
Discussion in 'Traditional Hot Rods' started by chiro, Jun 23, 2017.
  1. chiro
    chiro
    Does anybody make a ring to hold thermostats in place at the water outlet on the heads of 59AB flatheads?
    Thanks,
    Andy
  2. moonlight graham
    moonlight graham
    from wyo
    This might help. Slide the hose over the wire, then tighten clamp.
    Geoffrey
    The 39 guy likes this.
  3. Texas Webb
    Texas Webb
    Maybe a 1" slice of pipe-diameter of hose snug fit just above the stat.Copper would work.
  4. You can use a clunk of PVC pipe - held in place with a second hose clamp -- or a piece of stainless exhaust tubing (which is what I did on my last one).
  5. chiro
    chiro
    PVC is a good idea but I don't ever remember seeing it in 1 3/4" size.
  6. rjones35
    rjones35
    Not to sound like an idiot, I've never worked on a flathead anything, all my flathead info comes from you guys!!, but does the thermostat just sit there and then the hose gets slid over it, no housing or anything? What keeps the thermostat from moving around if thats the case?
  7. seb fontana
    seb fontana
    from ct
    I think the original thermostat for a 59ab was tubular and fit hose ***e..Thermostat in pic is later 8ba and just has a flange which fit the 8ba thermostat housing. Goeffrey's way is simple solution provided hole in water neck is decent size..
    rjones35 likes this.
  8. Atwater Mike
    Atwater Mike
    Go with Geoffrey's plan, copper wire. (or stainless) If the thermostat's O.D. is the same as the head's, the hose'll hold it... I did it this way in the old days, (1955 'til I 'outgrew' flatheads...around '62. Went HEMI.
    But Geoffrey's method removes any worry about them 'tipping', or moving.
    Thanks, Geoff...I'm back to building another .040" over 59AB! Using your 'wires'!
  9. wheeldog57
    wheeldog57
    Boryca likes this.
