59AB ignition ?'s
Discussion in 'The Hokey Ass Message Board' started by Abomb, Jan 10, 2007.
  1. Abomb
    Abomb
    Does anyone make an electronic ignition conversion for the 42-48 style front mount distibutor ? I have seen that pertronics make a kit for the old 8N ford tractor, but can't seem to find anything for the V8.
    Thanks in advance
  2. Jive-Bomber
    Jive-Bomber
    MODERATOR
    I recommend just buying the whole Mallory Unilite crab distributor- Works great, and you can paint the body black if it looks to billet-ish to you.
    There is a guy that converts the old dizzy's to electronic, but you have to send it to him and wait- It also costs quite a bit.
  3. lucky loony
    lucky loony
    from canada
  4. flathead A
    flathead A
    from michigan
    there was a post on this subject not to long ago.34fivewindow is rebuilding stock dizzy with mopar parts . you may want to talk to him.
  5. side_valve
    side_valve
    Alliance Vendor
    34fivewindow is converting the orginal dizzy to modern points.
    http://www.jalopyjournal.com/?p=620
    You may also want to try Remund Ignitions (Mickey Remund) - Rebuilds & sells early V8 distributors and coils (stock or electronic)
    P O Box 857
    Lemon Grove, CA 91946
    (619) 460-3620
