Technical 59AB weight?
Discussion in 'The Hokey Ass Message Board' started by Karl Grossman, Feb 5, 2020.
  1. Karl Grossman
    Karl Grossman
    Anyone know the approximate weight of a 59AB long block?
  2. Hnstray
    Hnstray
    from Quincy, IL
    @Karl Grossman
    600 lbs, more or less......heavy little ****ers....they weigh more than an SBC.
  3. A Boner
    A Boner
    How much does an early HEMI weigh?
  4. Hnstray
    Hnstray
    from Quincy, IL
    @a *****
    Chrysler.....760 lbs.......more or less, but that is very close. Dodge and DeSoto are about 100 lbs and 50 lbs less, respectively. That is ***uming all original cast iron components.
  5. Fortunateson
    Fortunateson
    How about a Henway?
  6. Hnstray
    Hnstray
    from Quincy, IL
    @Fortunateson
    Live weight...about four pounds.....more or less. “dressed”.....about half of that. ;)
    Desoto291Hemi likes this.
  7. 1946caddy
    1946caddy
    from washington
    Engine Displacement A
    length
    B
    length
    C
    height
    D
    height
    E
    width
    DIST SUMP STARTER OIL
    FILTER
    WEIGHT
    AMC
    250/287/327 x 27.75 24.00 x 24.12 rear rear right left rear 601
    AMC 304/360/401 28.75 29.25 21.25 29.50 21.50 front rear right right front 540/600
    Buick/Olds 215 x 28.00 x 27.00 26.00 front rear x right front 315
    Buick 350 29.00 30.50 21.50 28.50 23.00 front rear right right front 450
    Buick 322/425 x 33.50 x 29.00 28.00 rear rear left right rear 685
    Buick 400/455 29.00 30.00 22.00 30.00 23.00 front center right right front 600/640
    Cadillac 331/390 60-62 x x x x x rear rear left right rear 699/720
    Cadillac 331/390 63-up x x x x x rear rear left left front 699/720
    Cadillac 425/472/500 30.00 30.50 28.50 32.00 28.50 front rear right left front 625
    Chevy 262/400 Short WP 26.50 27.00 20.50 27.00 22.00 rear rear right left rear 575
    Chevy 262/400 Long WP 27.88 28.38 20.50 27.00 22.00 rear rear right left rear 575
    Chevy 348/409 x 34.50 x 32.00 28.50 rear rear right left rear 685
    Chevy 396/454 Short WP 30.50 30.50 23.50 33.00 27.00 rear rear right left rear 685
    Chevy 396/454 Long WP 32.00 32.00 23.50 33.00 27.00 rear rear right left rear 685
    Ford 221/302 27.00 29.00 22.00 27.00 22.00 front front right left front 440/460
    length
    B
    length
    C
    height
    D
    height
    E
    width
    FILTER
    WEIGHT
    Ford
    332/428FE 30.00 32.00 28.00 32.00 27.00 front front right left front 650
    Ford 427 SOHC 32.00 34.00 30.00 34.00 32.00 front front right left front 680
    Ford Flathead 30.00 30.00 22.00 x 26.00 front front left left rear 569
    Mopar 273/360 29.50 29.50 23.50 31.00 25.00 rear front left right rear 525/560
    Mopar V10 488/505 36.88 36.88 23.50 x 25.00 x front left right rear 716/816
    Mopar 350/440 29.00 30.00 24.00 30.50 29.50 front center left left front 620/670
    Mopar 331/392 Hemi 32.00 31.00 24.00 31.00 29.00 rear center left right rear 729/745
    Mopar Late Hemi 32.00 32.00 24.00 32.00 29.00 front center left left front 765
    Olds 303/394 x 32.00 x 29.00 30.00 rear rear right right rear 700
    Olds 350 28.25 28.25 20.25 27.50 26.00 rear rear left right rear 560
    Olds 455 29.00 31.00 24.00 31.00 26.50 rear rear left right rear 605
    Pontiac 350/400 28.25 29.00 20.00 31.00 27.00 rear rear left right rear 650
    Pontiac 455 29.50 32.00 27.00 33.00 27.00 rear rear left right rear 650
    Allison V12 1710 x 44.00 36.00 x 30.00 rear rear rear x 1160
    Merlin V12 1649 x 71.00 29.80 x 43.00 rear rear right x 1540
    length
    B
    length
    C
    height
    D
    height
    E
    width
    FILTER
    WEIGHT
    [​IMG] [​IMG]
    A - Length from rear of intake manifold to water pump pulley
    B - Length from rear mounting surface to water pump pulley
    C - Height from bottom of sump to highest point of intake manifold
    D - Height from bottom of sump to top of carburetor
    E - Width outside of valve cover to outside of valve cover
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    I know the weight of a Henway...
