6.50-16 tires
Discussion in 'The Hokey Ass Message Board' started by rafman, Sep 21, 2011.
  1. rafman
    rafman
    hi i have a question hopefully somebody out there answers it.it seems everytime i ask something no one replies. simple ques? i have a 47 chevy coupe it takes 6.00-16 bias ,i find a real good deal on some 6.50 -16 is there's much difference on the height or width? thankyou very much and i hope some can answer
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    All I know is they will be taller .Either half inch or inch.......
  3. Ice man
    Ice man
    JUst a tad larger. We used to upgrade them back when, to get a fuller looking tire. I am running 600X16s on my 29 Pk Up and since they are radials they are a bit larger the the old 600X16s. Thery are more like 650X16s or 700X16s but I have no fender clearence problems. Iceman
  4. rafman
    rafman
    finally i have friends thankyou for the info. gentlemen
  5. walls
    walls
    Go on the coker website to compare tire height.
    I have Coker 650x16s on my A. I think they look OK. They have a cool pie crust and are relatively cheap compared to Firestones.
  6. pick
    pick
    They're taller. The 6.50 on 35 ford rims have a like cir***ferance as '31 Ford 19" tires so many Model A guys use that set up
  7. As others have noted, it's a little taller tire. This can be a good thing, as most of the older cars are geared too low to cruise comfortably at 60+ MPH without the engine screaming. A taller tire has the same effect as a higher gear ratio, so you might notice a slight improvement in terms o fuel economy and the ratio of RPM to speed. My '38 Ford pickup came with 16x4 rims and 6.00x16 standard or 6.50x16 optional on the same size rim. Just about any vehice that came with 6.00x16's should be able to run 6.50's on the stock rims with more than adequate clearances.
  8. kyle paul
    kyle paul
    from sac
    6.50 16 Overall diameter: 29.38"
    Cross section: 7.53"
    Tread width: 5.00"
    6.00 16
    Overall diameter: 27.91"
    Cross section: 6.26"
    Tread width: 4.63"
  9. rafman
    rafman
    thankyou gents
