Technical 6/71 blower
Discussion in 'The Hokey Ass Message Board' started by vega1, Dec 16, 2017.
  1. vega1
    vega1
    [​IMG][​IMG][​IMG][​IMG]I'm sure it's been done before but I'll post it anyway did one last winter and now I'm on to another I know there are things I'll do when I rebuild mine that some don't but I have
    done one it works great so I'll start with this[​IMG][​IMG][​IMG][​IMG]
  2. vega1
    vega1
    This is the part that is really time making the ribs match side to side and sanding down the old rough casting consuming[​IMG][​IMG]
    Sent from my Pixel 2 using The H.A.M.B. mobile app
  3. vega1
    vega1
  4. Kan Kustom
    Kan Kustom
    Nice ! That thread heading always gets my attention.
    mad mikey and loudbang like this.
  5. mrhp
    mrhp
    from MICHIGAN
    I see many that do not match the ribs side to side. I had to match mine as well. If your gonna do it, do it well!
  6. DDDenny
    Roger that.
    Like a moth drawn to a flame, if your not; how can you call yourself a hot rodder.
    mad mikey and Kan Kustom like this.
  7. vega1
    vega1
    One rib left to match the shape then on to final cleaning and ***y. The new bearing endplate from Dpi has the look their parts are great[​IMG][​IMG][​IMG]
  8. vega1
    vega1
  9. Mike Colemire
    Mike Colemire
    I really like that rear plate.
    mad mikey likes this.
  10. DDDenny
    I see the factory ***embly support flanges on the bottom of the case have been removed, did you get the pleasure of doing that, not many people can say they have removed them. They are usually the first mod to a GMC casting when converting to non diesel use.
    Have you seen this HAMB thread?
    https://www.jalopyjournal.com/forum/threads/tech-week-6-71-blower-rebuild.367403/
  11. vega1
    vega1
    Yes I cut them ****ers off my case was a virgin I have seen said thread I agree with most of what was done in that thread I did not machine my gears on last one used the shims as Dean said he knows his stuff
  12. vega1
    vega1
    Thanks for the price and a local company only about 60 miles from me and has that nostalgic look
  13. Kan Kustom
    Kan Kustom
    I have to agree !
  14. Jalopy Joker
    Jalopy Joker
  15. vega1
    vega1
    Ok so I thought I would share these bearing numbers rear bearing number is. 62052rsc3. That is the sealed high speed number front open high speed is as follows Fit -093. I figured I'd share these part numbers as I bought a kit but I know you could source them cheaper the seals have no part number on the [​IMG][​IMG]
    mad mikey, loudbang and slack like this.
  16. Mike Colemire
    Mike Colemire
    Someone said you can buy those bearings at Tractor Supply, I never checked myself. Have you got a link or name for that rear plate?
  17. vega1
    vega1
  18. DDDenny
    Since I'm an anything 671 kind of guy; what ever came of the new cases they were doing?
  19. vega1
    vega1
    I have no clue seen the plans and the prototype never seen any completed
  20. DDDenny
    Their website shows a lot of blower related components, everything but the cases.
    When the owners son was posting regularly here it appeared they were in production.
    I do recall they were involved in other manufacturing unrelated to blowers.
    Being a retired machinist I imagine this was quite an undertaking and could have run into tooling issues.
  21. henryj1951
    henryj1951
    from USA
  22. big duece
    big duece
    from kansas
    I have their rear bearing plate too, machined to perfection. Their products are very reasonable for the quality they produce. I talked to the owner, and they do everything in house from design to foundry to machining. DSC09909.JPG
    Deuces, mad mikey and loudbang like this.
  23. vega1
    vega1
    mad mikey, loudbang and henryj1951 like this.
  24. simpsonrl
    simpsonrl
    Out of curiosity, when a 6-71 blower is converted and used for automotive use, how are the bearings lubricated? I am pretty sure that in the Detroit Diesel, they are oil feed.
    In my read of the modifications it almost sounds like the one end is filled with oil , and the other uses sealed bearings. But the rpm they are run at makes me wonder if that would be adequate.
    Thanks
  25. Mike Colemire
    Mike Colemire
    That's the way they are set up, sealed in the rear and oil in the front. I seen where a guy popped the outer dust shields off the rear bearings and installed grease fittings in the rear bearing plates.
  26. vega1
    vega1
    The rear bearings are sealed the fronts are open and wider then the rear the fronts have more load on them then rear the fronts are in oil
    simpsonrl and loudbang like this.
  27. wrenchbender
    wrenchbender
    I always put grease fittings on mine and use high temp grease to lubricate them periodically never had any trouble but like anything maintenance will prevent failure you just don't want to over do it or seal failure will result the front bearings are a double row ball bearing the rear are a single row roller bearing on a Detroit i typically use them instead of a single row ball bearing like the sealed ones you have shown just a personal preference also I prefer the double lip seals vs the single lip rubber seals that Detroit originally used however they are more difficult to install and need the proper tool to install and typically use a seal spacer installed on the rotor shaft Just my .02 cents after 200,000 trouble free miles on my avatar blower
    Gammz, mad mikey and big duece like this.
  28. simpsonrl
    simpsonrl
    Thanks. The grease fitting would be for the rear bearing? You must use a bearing that is sealed only on one side so the grease can get in?
    For the front bearing, the case area around the bearing is modified to allow filling with oil? What kind of oil? Motor oil? And how full? Maybe half way up the bearing?
    Is there a bearing in the nose of the extension housing near where the pulley is on the shaft? Or is it cantilevered and that is why the double row ball bearing in the front?
    Thanks. One of these days, I want a blown engine.
  29. gimpyshotrods
    gimpyshotrods
    simpsonrl likes this.
  30. simpsonrl
    simpsonrl
    Thanks Gimpy. I already read that.
