Technical 6/71 blower
Discussion in 'The Hokey Ass Message Board' started by vega1, Dec 16, 2017.
  1. 1946caddy
    1946caddy
    from washington
    About 15 years ago, at the company I used to work for, they put a GMC 671 motor up for bid at the surplus yard. I was bidding on some other stuff and bid $5.00 on it not really expecting or wanting it. I was the only bidder and really had no way to offload it from my truck bed. I took the blower off and sold it to a local truck repair place for s****. It's been kind of like garage mascot for the last 15 years laying under the work bench or wherever it gets pushed to when I need room.
  2. vega1
    vega1
    Wanna double your money on it haha I'll even pay the shipping
    Sent from my Pixel 2 using The H.A.M.B. mobile app
    Gammz and loudbang like this.
  3. Mike Colemire
    Mike Colemire
    I'll go $25 and pay shipping.
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Just in case you do buy or sell it. Costs $60 to ship one from GA to MI via Fastenal. You have to specify 'Parcel Shipping' for the good rate.
  5. 1946caddy
    1946caddy
    from washington
    It's become part of the family. I think I'll put wheels on it so it's easier to move.
  6. DDDenny
    If that was mine I'd put it out of sight just enough to see a couple of those yellow case ribs.
    Then wait for people eyes to light up the minute they spot it.
    Oh wait, I'm thinking how I'd react.
    Any body else have the same reaction looking at a big lump of aluminum.
  7. wrenchbender
    wrenchbender
    Yes the grease fitting is for rear bearings only the bearings I use in the rear have no seals in them but if you use the single row sealed ball bearing you can take the seal off the back side to allow the grease in
    The drive snout has a bearing in it too I use 80/90 gear oil in the front cover to lube everything I usually just fill to the lower bolt hole in the triangle plate I install a pressure relief valve in the top of the front cover and that's where I fill it at then remove the lower bolt of the triangle plate when the oil runs out just put the bolt back in then the pressure relief valve
    If you use stock bearing plates you need to install freeze plugs in the lower corner hole or the gear oil will run out lol those are oil drain back holes on a Detroit diesel
    When I get home after the holidays I'll try to get some pics posted
    Chrome don't get ya home
    mad mikey, simpsonrl and loudbang like this.
  8. big duece
    big duece
    from kansas
    I found my 671 in a salvage yard I had been going to for years. Finally looked inside a 50's GMC school bus that I had walked by several times, and there it was, first seat behind the drivers seat.
    mad mikey and loudbang like this.
  9. simpsonrl
    simpsonrl
    Looks like it may have been from a marine engine. I think that is the raw water pump?
  10. big duece
    big duece
    from kansas
    My understanding it came from a 671 Detroit from a truck, it was very greasy when I brought it home. I have seen others with the same water pump.
    mad mikey likes this.
  11. simpsonrl
    simpsonrl
    How do you know how much boost you can run with an otherwise mostly stock engine? I know the actual boost pressure would be dependent on the air restrictions in the intake manifold, heads, exhaust, etc. Just watch for pre-ignition, overheating, etc?
    Thanks
  12. wrenchbender
    wrenchbender
    Experience tells me that if it doesn't have forged pistons don't run more than 5 lbs of boost
    Gammz, simpsonrl and mad mikey like this.
  13. wrenchbender
    wrenchbender
    No that is the water pump on a 6-71 Detroit there are other accessory drives on the engine for things like power steering, air compressor, and all other things that need to be gear driven most accessories like the pump you are speaking of were belt driven at least in the dry land area of things lol haven't had much experience with marine stuff since I live in the middle of the country lol
    mad mikey and simpsonrl like this.
  14. vega1
    vega1
    I was just at tractor supply and yes the have the bearings the exact number I posted
  15. metlmunchr
    metlmunchr
    Considering a major failure of a bearing will likely wreck both the rotors and the case, I'd spring for bearings of higher quality than the typical no-name Chinese bearings found at tractor supply. You can get 6205 2RS bearings from Amazon for around $15 each in quality brands like SKF or Nachi. You can also buy 6205's in quan***ies of 10 from unknown Chinese manufacturers for less than $2 each. There's a reason for the difference in price.
  16. vega1
    vega1
    I was saying that these are the numbers that were in the kit not saying anything but that do what you will with numbers buy whatever bearings you like just trying to help save some money with the part numbers
  17. DDDenny
    There are just some things that should not be Walmarted!
    I place bearings at the top of that list.
  18. vega1
    vega1
    Like I said DO WHAT YOU WANT WITH THE NUMBERS cross reference buy Chinese ones buy Jap buy use whatever. As I stated I'm sure you can buy them cheaper then the kit I bought some of you people would pick fly **** out of pepper .
  19. big duece
    big duece
    from kansas
    Those guys that can pick fly **** out of pepper work for bearing companies, like Timken.
    loudbang and vega1 like this.
  20. DDDenny
    Hell, get your bearings at H.F. then you can throw your blower in the corner with all your other s****.
    metlmunchr and mad mikey like this.
  21. vega1
    vega1
    I'm using them right now just got back with a new set I like em alot the sloppy bearings add to that whining sound from the blower .Some people you could hang with a brand new rope and they would complain
  22. vega1
    vega1
  23. Deuces
    Deuces
    Wow.... Tough crowd... :rolleyes:
    Don't think this thread is gonna last that long with every body bickering.... Chill out, have a gl*** of wine or something... ;)
    loudbang, XXL__, INVISIBLEKID and 2 others like this.
  24. seb fontana
    seb fontana
    from ct
    I think I have a Bunch of NOS 6205 bearings; should I look for them?
    vega1 likes this.
  25. vega1
    vega1
    I'd say so
  26. Mike Colemire
    Mike Colemire
    Bought mine from Deans blowers.
  27. saltflats
    saltflats
    from Missouri
    All bearings aside....you got this polished yet. :D
    Gammz, vega1, loudbang and 1 other person like this.
  28. vega1
    vega1
    Not polishing it I'm not a fan of polished satin finish it is all together though
    Deuces, loudbang and gimpyshotrods like this.
  29. vega1
    vega1
    Fordors, gimpyshotrods and saltflats like this.
  30. gimpyshotrods
    gimpyshotrods
    Hella s****!
    I am doing mine satin, too.
    Gammz likes this.
