6 Lug Chevy Wheels and an S10 Rear End?!
Discussion in 'The Hokey Ass Message Board' started by Flop, Nov 11, 2010.
  1. Toyota 4Runner (my daily driver) will work- I'm working on a '28 Chevy with disk wheels and they match up perfectly.
  2. rcnut223
    rcnut223
    from wisconsin
    I have a set of 5 to 6 lug adapters.
    PM me
  3. perhaps I can help, I have 3 Isuzu rear ends, 2 with drum brakes and one with disc brakes. They have the correct 6 on 5.5" bolt pattern (same as early Chevy, same as 6 lug Toyota and Nissan. The 93 trooper disc brake rear end is a very stout piece. I currently run one in my 41 Chevy 6 wheeler. The track width should be around 62 inches. I had the driveline company modify the Isuzu shaft with a TH350 yolk on front. The ratio is 4.55 to 1.
  4. here is my orginal crusty cruiser with the Isuzu drum brake rear end and blazer 15x8 wheels on rear and nissan wheels up front.
  5. stillrunners
    stillrunners
    from dallas
    LUV LUV LUV....just saying...because two of them little pickups showed up in the yard this week....yes I know who built them....but hey they do have a Bow Tie on them....and they're six lug....hehehe
  6. Late model Astro vans came with 6 lug axles. I don't know how wide they are.
  7. laloszephyr
    laloszephyr
    my brother had the same situation on his 38 coupe.he wanted to keep the same look only because he had the artillery wheel so he went with the adapter.since the original wheel is a 5.5 width the adapter worked out good.but i have to say i learned somthing new and will try the maxda rear on future projects,good info as usual.
  8. :D Thought I'd share some information about a 6 lug rear end with disc brakes, the differential is a Dana 44. Would you believe, it came under a 96 Honda P***port Suv (built by Isuzu and rebadged as a P***port). I will measure the track width and post it later.
