Technical 6 to 12 volt conversion
Discussion in 'The Hokey Ass Message Board' started by RAF, Aug 30, 2017.
  1. RAF
    RAF
    from MA.
    I am converting my 40 Ford to 12 volts and will retain the stock wiring harness as it is fairly new. Have changed generator , regulator, coil, solenoid, bulbs, horn relay to 12 volts. Question is do I remove the old resistor and if so what do I do with the wires? Any help appreciated. Have done searches but can't find the info I am looking for.
  2. Budget36
    Budget36
    Depends on the coil you used, and how much voltage you need to drop.
    You'll also have to reduce the voltages to the gauges as well.
