Customs 6 V, + ground gas gauge....
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Mar 18, 2020.
  1. flynbrian48
    flynbrian48
    I’m doing the fuel system for my ‘52 DeSoto wagon and before the tank goes back in for good, here’s a dumb question: The car was 6V + ground. Now it’ll be 12V - ground. I’d like to keep the original gauges, oil and temp are manual and I have ports in the new engine to put the senders, ammeter I’m not using, and the speedometer I can drive with a pulse generator from the new overdrive transmission. Fuel gauges care about Ohms of resistance, not voltage or polarity, can I use the original gauge and sender, since they’re “matched”? IMG_0486.JPG IMG_0481.JPG IMG_0475.JPG
  2. tb33anda3rd
    tb33anda3rd
    you would need a runtz voltage reducer
  3. flynbrian48
    flynbrian48
    Not arguing, but I've run GM 6V gas gauges on 12V and they work fine. My question is does the polarity make a difference? Or should I just get a new gauge and sender, and adapt the gauge to fit behind the original gauge face?
  4. junkyardjeff
    junkyardjeff
    I am using the original gauges in my 55 Ford that were originally 6 volt positive ground on 12 volts with no problems,I did not have to reverse connections but did use a reducer.
    flynbrian48 likes this.
  5. tb33anda3rd
    tb33anda3rd
    I have never seen a 6 volt fuel gage work on 12 volts without a voltage reducer of some kind. they usually come into my shop with a gage that needs replacing. the senders don't care about voltage but the gages burn up.
