6 V +pos ground with 12v -neg ground..???
Discussion in 'The Hokey Ass Message Board' started by Plymouth, Apr 11, 2011.
  1. Plymouth
    Plymouth
    I know I am going to use a small 12 Volt battery to operated my wedding horns..
    BUT I was wondering since my car is 6 volt positive ground DO I have to insulate the 12 volt horn ground (which will be 12 volts )
    The horns will have there own switch Just want to make sure nothing goes wrong before I wire it up this way .. Thanks..........
  2. yeah I would say it has to be insulated... should be really easy, just mount the horns with nylon nuts and bolts with washers, and separate wires for power and ground...
  3. junk yard kid
    junk yard kid
    thats an interesting question i dont know
  4. d2_willys
    d2_willys
    from Kansas
    U sure about that! The horns themselves isolate the +12V from the -6V. Think about it!
  5. plym_46
    plym_46
    from central NY
    I believe I read somewhere that the cassis can be used as a common ground for both systems since it carries no load. However, can you not mount the aux horns on a board and run the wiring between the battery, switch and horn then from horn to negative of the 12v power source??? Better yet just run the horns off a jumper pack and wire the whole thing to the acc plug on the jumper.
    The frame provides a floating gound, not a definitive earth conection. As such it is merely a node for electrons to travel on or through, Functionally it doesn't care which way the electrons flow and will conduct either or without much fuss. The electrons will flow the way they know.
  6. ddawg16
    ddawg16
    from So CA
    As long as nothing else is connected to it....it does not matter which term of the batter you use....
    Lets say the horns are used to being grounded....ok....with nothing else connected to them....the battery negative is a -6v away from that ground.
    Now....you hook up the 12V battery....you connect the neg to ground...and the postive to a button which will then go to the horns....
    Nothing will blow up. The horns are operating off 12v. Just don't try to connect any of your other car components to the 12v battery. If you meas from the pos of your 12v to the neg of your 6v, you will have 18v.
  7. I still would say play it safe.. isolate it... your looking at an extra 2 or so dollars for the nylon fasteners and wires....
  8. Hnstray
    Hnstray
    from Quincy, IL
    Rube Goldberg would be proud of you guys........... :)
    Ray
  9. I love it......fireworks in the spring time.....fried chicken and I helped....
    Uh, its POSITIVE ground on the car and NEGATIVE ground on the horn.......
    Insulate the horn from touching ANYTHING metal in the car, hook up a separate ground and postive to the 12 v battery run your switch by cutting into either wire, then to the horn....beep beep....
  10. d2_willys
    d2_willys
    from Kansas
    Explained perfectly! You could even run the horns from a horn relay that is connected to the +12V and gets (the relay's coil) .grounded via a button to ground. The horns come off the horn relay contact terminal that gets +12V.
    Only fireworks are on the 5th of July!
  11. Commodoreswab
    Commodoreswab
    from West TN
    how about running the horns positive ground?
  12. Conch...are you trying to confuse him even more..........
  13. Mr48chev
    To be safe I'd just make it a completely isolated circuit.
    Mount the horns so that they are insulated from the car's metal. run a ground wire from the horns to the battery. Run a wire from the battery to that set of horns horn button, wire to their horn relay and a wire from relay to horns and you are done. The relay should be mounted on the bracket that the horns are on and isolated from the car it's self. Easy to install and easy to take out when you get tired of messing with them. Just remember to charge the battery.
  14. plym_46
    plym_46
    from central NY
    Lucy, you got some splainin to do. 6v+ and 12V - all playing their own tunes with a common ground.
    No sparks, no sploding batterys, no 4th of july, except in July, on the 4th.
    How do they do it????
  15. 39 chevy kustom
    39 chevy kustom
    a ground is a ground , pos to groud , neg to groud , still a ground you all are really making this complecated , i know several peaple runnuing there flat head starters on a 12v neg groud and runnuing the ignition qn 6v pos. ground as long as the right v batt is hooked the to right things no problem , simply a ground is a ground.
  16. 39 chevy kustom
    39 chevy kustom
    a ground is a ground pos or neg, ^^^by the way ,on your signature , because its not called a level head, the walls in you house are vertical right? and they are still flat and the photc looks like they are vertical not slanted[​IMG]
  17. Ogbomb
    Ogbomb
    A horn is just a coil of wire and a diaphragm and will make noise no matter which way it is earthed as long as current is flowing, if you look at late model 2 wire horns you can hook them up either way and they will still make noise.
    In this case, i would mount up your 12v battery and take the positive to earth. Get a 6 volt relay, in most cases the terminal numbering is universal. Take 6v negative to terminal 85, connect terminal 86 to horn button which in turn will go to earth. Connect 12v nefative to terminal 30 and connect terminal 87 to your horns.
    So now we are using 6 volts to switch a 12 volt supply and you should have no hassles, other than the 12v battery will not be getting charged by the generator/alternator.
    There is also a way to do this using 2x 6 volt batteries in parallel, and then using relays to connect the batteries in series to give 12 volts while not affecting anything else while both batteries being charged off the generator. This way is a bit more involved circuit wise and best explained with a diagram, can be drawn up if required.
    Hope this helps,
    Chris.
  18. shmoozo
    shmoozo
    from Media, PA
    Folks, if you're thinking you can't run two different voltages or even two different polarities on the same common chassis ground, then consider this. The home computers a lot of you are reading this message on have various bits and pieces operating on +12 volts, +5 volts, +3.3 volts, and -12 volts. And they're all driven by a collection of wires coming out of a single power supply with a single common chassis ground. It's really just a matter of wiring all of the various parts properly, you see.
    :cool:
  19. Hnstray
    Hnstray
    from Quincy, IL
    Anybody bring popcorn???????
    Ray
  20. plym_46
    plym_46
    from central NY
    What voltage you runing your popcorn popper on??? Uing 2 6V batterys seems to deal with all concerns.
  21. Hnstray
    Hnstray
    from Quincy, IL
    The popcorn is to munch on while reading these posts!
    Ray
  22. d2_willys
    d2_willys
    from Kansas
    Yes, but the common to either -v or +v is only 6v, need 12V to common. If he uses existing 6v for power supply 2 and new 12v for power supply 1, then he can use the horns that can connect directly to frame ground (common). And if someone wants to pop popcorn, they can use both battrees in series and get whopping 18V. Yes I too believe this is becoming something out of the movies. Jiffypop live on!
  23. Ogbomb
    Ogbomb
    Your'e right, as i said in my earlier post, you can run 2x 6volt batteries in parallel which still gives 6v. By using relays you can put the 2 batteries into series giving 12v but not affecting the 6v operation of the car. Just like Kenworth trucks using a series/parallel switch which gives 24v starting only and 12v everything else.
  24. Fenders
    Fenders
    Short answer... no, you can ground the - (neg) side of the 12V battery and switch the + (pos) side to operate the horn.
    There will be no interaction between the two voltage systems.
  25. Nomadder01
    Nomadder01
  26. plymouth52
    plymouth52
    Alot of Incorrect info here in these posts
    NO switching to Negative ground Won't make your starter run backwards
    The Power Lead is Power Lead. + or - it does not matter
    There is only two components that won't work: Radio and Gas Gauge
    which are easy fixes.
    This horn issue is this simple:
    Isolate the one horn by running the Ground out of the First in the Power of the second.
    the Drop takes the 12 V splits in half to 2 6 volt horns
    Gas Gauge is fixed by changing to 59 Belvedere sender, or a GM aftermarket.
    same with the overdrive motor.
    People get crazy ideas about electricity sometimes.
    KEEP IT SIMPLE.
    If anybody thinks I am wrong, I will be more than happy to make a video of the working horns in mine.
  27. manyolcars
    manyolcars
    this thread is so full of WRONG. I hope your government doesnt find out that you guys work on cars. They will shut us all down
  28. You guys are all wayyyyy off. If you hook the horn up backwards it will suck instead of blow.
  29. Mike51Merc
    Mike51Merc
    So? Wolf whistles suck instead of blow...
