6 Volt/12 Volt Conv....
Discussion in 'The Hokey Ass Message Board' started by taskforceranger506, Jul 20, 2006.
  1. taskforceranger506
    taskforceranger506
    Just wondering what info I can attain in getting my 6 volt system converted over to 12 volt. I have a 1955 Dodge Custom Royal Lancer 270 S.R.R. Hemi that runs with 6 volts. Now my main concern is not to damage the Gauges. Thanks for any help,...IRAQ Anyone with this type of car sitting around for parts or else?....:cool:
  2. DrDano
    DrDano
    Alliance Vendor
    Swapping to 12v is a bit of work, but is all kinda small stuff. Here is some of the things you'll need to do for the swap:
    Convert generator to 12 volts
    Swap regulator to match new generator
    Install ballast to coil and distributor
    Install voltage drops to gauges, radio and heater, etc.
    Swap out 6v bulbs for 12v ones
    Thats the general list for about any car to convert over from 6v to 12v. Might be other small items to address on yours. Also, its usually not required to convert the starter over to 12v. However, in some cases if the starter is consistantly destroying drives, 12v conversion may help.
    All of the items above are things you can probably do yourself. If your not comfortable swapping the fields in the generator yourself, our shop can do it for you and supply a new regulator. Thats my shameless plug for this post. Let me know if you have other questions and good luck. :)
  3. taskforceranger506
    taskforceranger506
    Thanks for the info...I'm going to install a 331 Hemi Chrysler Industrial in her instead of the Hemi 270...As for electrical, nothing major else needs to be mentioned you have not already said to do? I know I'll have to make motor mounts for her to fit. What about the Trannie setup, can I use the original Trans? 2 speed Powerflite. Maybe to much horse power for such a small tranny?:eek:
  4. arkiehotrods
    arkiehotrods
    Powerflites were used behind Hemis from the factory. Shouldn't be a problem. It's a good tranny. I had one in a 54 DeSoto.
  5. taskforceranger506
    taskforceranger506
    Great so it should bolt right up to the 331 Hemi? I hope so because I had it rebiult right before coming to IRAQ. All the questions because I'm here and not there, hard to put my hands on stuff so I ask...this is such a great forum for information.:D
  6. bobw
    bobw
    Speedway Motors in Lincoln Ne. sells a voltage drop device called a Runtz that is designed for use with gauges.
  7. taskforceranger506
    taskforceranger506
    Easy to get a hold of there in Neb? Part good quality? Thanks. 12 volt is the only way to go.:D
  8. DrDano
    DrDano
    Alliance Vendor
    Runtz are good little voltage drops, they've been around for a long time. If you've got your heart set on going 12v, you'll prolly just need what I posted above. 6v systems are pretty reliable and work well if you maintain everything. The 331 would be 6v (unless it was already converted over) and would easily go right into the 6v system that your old mill. Just food for thought.
  9. taskforceranger506
    taskforceranger506
    the 1945 331 I have sits on a pump skid and ran off propane fuel...so running 12 volt be ok?:cool:
  10. DrDano
    DrDano
    Alliance Vendor
    I thought the 331's were '52-'54? Yea, you can run it, but you'll need a voltage regulator and the other items on that list of stuff.
  11. breeder
    breeder
    mmm...the 270 would look nice in my livingroom:D pm me if your gettin rid of it....i know a guy that might use it in his sedan...cnat think of his name right now...:eek: ;) ..
    ps....thanks for being the man!!!!hooraa!!!:)
