Technical 6 volt/12 volt question
Discussion in 'Traditional Hot Rods' started by fyrffytr1, Nov 21, 2019.
  1. fyrffytr1
    fyrffytr1
    I know you are not supposed to run six volt stuff like gauges, switches and lights on 12 volts, but can you use a 12 volt headlight switch in a 6 volt system?
  2. Boneyard51
    Boneyard51
    It will work, but 6 volt switches are have larger contacts that 12 volt switches. It may heat up.
    Bones
  3. Truck64
    Truck64
    from Ioway
    I thought 6 volt stuff was built beefier to handle more current. Not saying you're wrong, just that this is opposite to what I would expect. The cables are larger, that's a good thing. Why not the switches?
    Boneyard51 likes this.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    12 volt electrical components draw half the current of 6 volt components...
  5. You need to reread the question, the poster is asking about using a 12 volt switch on a 6 volt system. I don't think I would do it.
    Charlie Stephens
    Truck64 likes this.
  6. Boneyard51
    Boneyard51
    Truck64, reread my post, I said six volt switches had larger contacts, thus “ beefier” . And a 12 volt switch may heat up on a 6 volt system. Maybe I should have said 12 volt switches have smaller contacts than 6 volt switches. Lol
    Bones
  7. If you have any doubt about the contact rating of the 12 volt switch, you can still use it with a relay.
  8. Truck64
    Truck64
    from Ioway
    I must be slysdexic! Never mind...
  9. JeffB2
    JeffB2
    from Phoenix,AZ
  10. fyrffytr1
    fyrffytr1
    Thanks for the replies. If a 6 volt switch is beefier would it be better to use than a 12 volt? I currently have a 39 Pontiac with a six volt system and I am thinking about changing to a 12 volt system somewhere down the line.
  11. Boneyard51
    Boneyard51
    Yes keep the switch and the starter. Six volt starters love 12 volts, as long as you don’t grind on the for an extended time. Heater motor??? Might be ok. Wiring will be fine. Gauges won’t work. Turn signals will need a 12 volt blinker. Bulbs will need to be 12 volt.....and probably some other things.
    Edit: radio won’t work.
    Bones
  12. squirrel
    That depends. What 12v switch is it?
    late 50s GM light switches have a couple built in circuit breakers...if you double the current, they might or might not open when they shouldn't.
    The contacts in any switch are designed for a certain amount of current, plus a safety factor. You don't know what the design spec is for any headlight switch, really...except that it was designed to last in it's original application. Could it be that it was designed with a safety factor of 10? or 4? or 2? or 1.5?
  13. fyrffytr1
    fyrffytr1
    Again, thanks for the replies. I think I will wait until I decide whether I am going to convert to a 12 volt system before I buy any electrical.
