6 volt AC fuel pump questions?
Discussion in 'The Hokey Ass Message Board' started by Bodger45, Aug 7, 2010.
  1. Bodger45
    Bodger45
    I know it is a long shot but does anyone know where I might find a rubber bellows like the one pictured? It's for an AC 6 volt fuel pump model number 6VEP-11 also there's also a 9-79 stamped on it I am ***uming thats the date code. It was NOS when I got it and I have about 50 hrs on it. Did they ever make rebuild kits for these? A google search wasn't helpful. Thanks, TK
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    that looks like the "Walbro" style ,try searching on that.
  3. Bodger45
    Bodger45
    Thanks John,
    They have a bellows in one of their rebuild kits that looks identical. I'll call them Monday.
    TK
  4. 51PanelMan
    51PanelMan
    I have the same pump. I tried it yesterday after it sat unused in the truck for 5 years. It rattles very loudly, but doesn't pump. I really like this pump and want to rebuild it.
    Did you have any luck in finding a rebuild kit for this pump?
    Thanks.
  5. Bodger45
    Bodger45
    I did have luck. I got a rebuild kit at Auto Performance Engineering http://www.APEusa.com I guess the new gas eats the rubber bellows. He recommends flushing it out with mineral spirits occasionally. The bellows kit is $8.75.
    TK
  6. d2_willys
    d2_willys
    from Kansas
    The ethanol doesn't do rubber any good.
  7. 51PanelMan
    51PanelMan
    Thanks for the info. I just ordered four kits.
    I have two pumps. One is a 6v and the other is a 12v. Both had the rubber bellows eaten up and distorted by the gas. The rubber turned into a substance similar to weatherstrip adhesive or gl*** urethane.
  8. chevyfordman
    chevyfordman
    I got tired of rebuilding those pumps, its easier to change to a all type fuel pump and you don't have to worry about the points corroding any.
  9. Bodger45
    Bodger45
    I bought three kits when I use those up I'll switch to another type pump.
  10. 51PanelMan
    51PanelMan
    I'm thinking I should get a few more. I'll wait until I get the four in the mail though.
  11. grancuda
    grancuda
  12. Bodger45
    Bodger45
    My last rubber bellows lasted about 10 hrs. So I just switched to this Carter 6v pump.
