Technical 6 volt alternator...why not?
Discussion in 'The Hokey Ass Message Board' started by 1951Merk, Aug 17, 2015.
  1. 1951Merk
    1951Merk
    Aside from losing the look of a generator....any reason why a single wire positive ground alternator wouldn't be a good idea?
  2. Does someone make a 6V alt? Just curious.
    I knew a guy that out a 12V one wire on his old chebby but wanted it to look like an early alternator swap so he snagged a GM regulator for an early external regulator alternator and gutted and used it as a junction box. Fooled lots of folks.
  3. Vimtage Iron
    Vimtage Iron
    6 Volt alt are out there the model A people use them.
  4. 4dFord/SC
    4dFord/SC
  5. I'll have to check that out. When I first joined the HAMB before alternators that looked like generators were readily available, they were out there just not within reach of most of us, a lot of the fellas were putting a mini alt like off of a Toyota inside a gutted jenny case.
    Just checked I wonder what they charge, something to think about incase I ever decide I have to have a generator look.
    @1951Merk @Vimtage Iron I just hadn't seen one yet. I guess I should have guessed that they exist. my curiosity always gets the best of me, but it has caused me to learn a lot of things. So I am a pain in the neck to lots of folks but it has been good for me. :D
  6. 1951Merk
    1951Merk
    Yeah they are our there... just thinking about making the switch whenever my generator decides to try and die.
  7. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    All the Model A stores carry them. They go for about $150 for 30 amp and about $175 for 60 amp. Lots of Model A guys run them and swear by them.
  8. Mr48chev
    I saw something on 6 volt alternators or converting a 12 v alternator to 6V this weekend when I was looking for a photo on how parts went back together in a 27SI alternator.
    Ford barn link http://www.fordbarn.com/forum/showthread.php?t=55923
    link for 6V + ground alternator http://www.qualitypowerauto.com/item_24/6-Volt-Alternators-Positive-Ground.htm
    A crap load of 6V neg ground alternators in this google search plus some non 6v stuff thrown in per google
    https://www.google.com/search?q=con...&oe=utf-8#q=6+volt+alternator+negative+ground
  9. junior 1957
    junior 1957
    go to a local alternator shop, i had built for a tractor, one wire gm. it just takes a special regulator form what i remember, cost was under $100 out the door
