Hot Rods 6 Volt electric choke
Discussion in 'The Hokey Ass Message Board' started by terry1974, Dec 30, 2015.
  1. terry1974
    terry1974
    I want to put a 600 edelbrock electric choke carb on my 54 Chrysler New Yorker that has a 6 volt positive ground electrical system. Is this possible?
  2. Rusty O'Toole
    Rusty O'Toole
    Do they make a 6v electric choke? If they do it won't care if it is + or - ground. If not you will have to make other arrangements. Easiest would be a hot air choke taken off the exhaust, I think that is what Chryslers had stock.
  3. ClayMart
    ClayMart
    I'd suspect it might work, but not as efficiently as it would with 12 volts. With the choke adjusted properly for cold starting, it may never open fully at normal engine operating temperatures. Adjust it to open fully and it probably won't close sufficiently for proper cold starting.
    But if you feel like experimenting, just to prove or disprove a point, you might try heating the choke thermostat electrically and adding an additional source of heat. Depending on how things are laid out under the hood, you might try splicing the heater inlet hose and rerouting a section of it near the choke thermostat cover. Many older cars, I'm thinking Fords in particular, had a metal tab on the choke housing that held the heater hose up snug against the choke stat cover. On some models coolant was actually plumbed thru the choke housing to supply heat to the thermostat.
    You might also need to add a bit of a tin shield ahead of the choke housing to keep under-hood air flow from cooling the choke thermostat. Or you could also convert it over to a manual choke, but where's the fun in that? :rolleyes:
  4. abes-NYPD
    abes-NYPD
    I am bumping this thread from the way-back machine, it is a dilemma I will be soon facing.
    My '54 NYpD sat for 60 years, it has the Original Carter 2041S WCFB. This car was miraculously complete under the hood with the exception of the heat tube riser from the manifold and the choke thermostat ***embly...
    I can try to find the original pieces on Flea-bay, and spend on a kit that is available for a 70 year old Carb with unknown condition, or I can go with an adaptor and a modern-ish fuel makin' happener....
    I intend to keep the original 6V electrical system...
    Was the question ever answered for the OP if there is a 6V solution for the Electric choke? I am not opposed to setting up a manual system on a new carb, which would be my 2nd choice over making the old Carter serviceable again.
    vtx1800 likes this.
  5. d2_willys
    d2_willys
    from Kansas
    Depending on what your 12v electric choke draws in current @ 12 volts, you may be able to find a DC to DC module that will convert the 6v to 12v. Probably around $5-10.
    vtx1800 likes this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    An electric choke draws about 1 amp so a DC-DC converter is potentialy a good option.
  7. FritzJr
    FritzJr
    You could just measure the resistance of the electric choke and add a resistor of the same ohm rating in series. This will give you the same current flow on 12 Volt as the choke alone on 6 Volt,.
    abes-NYPD likes this.
  8. jimmy six
    jimmy six
    I only adjust the mechanical exhaust fed choke on my WCFB’s enough to put the fast idle screw on the first step. I always let the engine warm about 1 minute. May take 2 pumps on initial cold start up.
    If you try a 12v on a 6v system like said above it will heat the choke body just slower. Setting the choke flapper only enough to get to the first step ***ures you’re not sealing off air to the engine. I’m guessing the fast idle will be the best and won’t fuel wash the cylinders. Good luck.
  9. d2_willys
    d2_willys
    from Kansas
    Johnny Gee and abes-NYPD like this.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    What diameter is it? I've got a few of these, new in the boxes, from the 6 volt era. 20240221_183707.jpg
    VANDENPLAS and Johnny Gee like this.
  11. abes-NYPD
    abes-NYPD
    Hi Heathen, are you asking for the carter choke housing diameter?
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
  13. abes-NYPD
    abes-NYPD
    Hi sorry for the late reply, had a death in the family and the car took the backseat.
    My choke housing, what is left of it appears to be exactly 2 inches.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm at a swap meet in Butler PA right now. I'll check it out when I get home on Sunday.
