Technical 6 Volt Generator Test
Discussion in 'The Hokey Ass Message Board' started by Robert Stanley, Nov 4, 2024.
  1. Robert Stanley
    Robert Stanley
    Bench testing a '37 '38 flathead 6 volt generator. Hot wired to the 6 volt battery it motors as it should but the wrong direction, from front of generator it turns counterclockwise. Does it matter which way as long as it turns? Then what about polarity?
    Thanks to all, Bob Stanley
  2. patsurf
    patsurf
    think it has to spin the direction it will be driven--not positive (no pun intended)
  3. Robert Stanley
    Robert Stanley
    I have another about the same vintage, tested it, it motors clockwise like it should.
  4. jaracer
    jaracer
    I never considered direction of rotation when testing a generator this way. My guess is that the field polatity may be backwards. That's one reason to "polarize" a generator.
  5. patsurf
    patsurf
    exactly...
  6. Are you hooking it up pos to ground?
  7. Robert Stanley
    Robert Stanley
    Yes, positive ground.
  8. Budget36
    Budget36
    I don’t think it makes a difference in rotation on a starter. I went to 12v battery, I just used different cables, and went negative ground.
    Edit, you guys are speaking of the generator.
    Disregard my babble.
