Technical 6 volt horn question
Discussion in 'Traditional Hot Rods' started by fnjunk, Feb 9, 2016.
  1. fnjunk
    fnjunk
    from Australia
    Hi I'm after some info I am wanting to use a old Indian motorcycle horn in my 33 Ford.
    Thing is the car is now 12volt,do I need some sort of voltage reducer or can I just supply 12v to it.
    It's not a cheap horn so I don't really want to destroy it.
    Thanks Fnjunk
  2. joee
    joee
    use a voltage reducer.....probably one of the vendors on here or speedway
  3. lothiandon1940
    lothiandon1940
    An occasional short "beep" probably won't hurt it but, if you get aggravated at someone and really "lay" on it, there could be some damage.:D
  4. khead47
    khead47
    I've never had issues using a 6V horn on 12V, but I use brakes more than the horn.
    lothiandon1940 likes this.
  5. lucas doolin
    lucas doolin
    Put a pair of 40s Fomoco trumpets (6 volt) behind the grille of my '56 Victoria. They were LOUD! and I didn't have to lean on the horn ****on for long. They commanded attention. Although my installation was topped by a friend who installed an 18-wheeler air horn in his small Datsun pickup. Would charge up an air tank and then wait for some **** not paying attention to do something stupid, like read a paper and drink coffee while driving. A good blast on the air horn (the victim thinking he was about to be crushed to death by a charging 18-wheeler) encouraged a change of behavior - hot coffee spilled in the crotch - followed by a perplexed look when no semi was in sight. Of course my friend would do a perfect eyes-straight-ahead-it couldn't possibly be me routine. Go ahead and use it as is, and enjoy the results.
    Truck64, Model T1 and lothiandon1940 like this.
  6. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    I used a 30's 6 volt horn for years with no problem with 12v. If the Indian horn is valuable I would probably go the reducer just to protects its value.
  7. 1934coupe
    1934coupe
    I had the original "Klaxon" horn on my Willys ran it on 12V never had a problem.
    Pat
  8. 56sedandelivery
    56sedandelivery
    Use it as is, just follow the above advice. A 6 volt horn on 12 volts will be LOUDER!
    I am Butch/56sedandelivery.
  9. Model T1
    Model T1
    All of the above. I did it for years and didn't know any better. Now I know better and still have a 6V horn on a 12V system.:)
  10. jimmy six
    jimmy six
    Make sure the relay is good.
  11. rramjet
    rramjet
    Put a couple of 6 volt horns (Hi and Lo) on wife's 50 Chevy with 12 volts. Really loud!!! Had to step up from a 10 Amp to 20 Amp fuse. Short blasts is all that's needed.
  12. Jeff34
    Jeff34
    I run my 6 V siren with a 12V battery. Spools up faster and much louder than with a 6V supply. Short bursts only, but works great!
  13. gwhite
    gwhite
    SUPER MODERATOR
    You might have to tune the horn...yours should have some 'tuneability'...I have Schwarze "pilot" horn (a pancake horn similar to the Indian you're wanting to use), that needed a good cleaning and tune.
    Can't speak for 12v operation (I'm staying 6 as God & Henry Ford intended), but there should be enough adjustability on the diaphragm to make it work with most voltage/amperage combinations.
  14. blackanblue
    blackanblue
    As others have said short blasts,much louder same as 6v starters much faster but shorter periods they have heavyer windings done it many times, voltage reducers do work or they can be rewound for$$$
  15. BamaMav
    BamaMav
    from Berry, AL
    I am using the original 6 volt positive ground horns on my now 12 volt negative ground 47 Lincoln. Like said above, short bursts, and they are LOUD!!!! They are louder than the mosquito fart air horn on my 09 IH semi tractor!
  16. scrap metal 48
    scrap metal 48
    That's good to know.. I've been tying to sell these with no luck.. Think I'll put them back on my 12V 38... 100_3421.JPG 100_3423.JPG
  17. blackanblue
    blackanblue
    Ya keep um and use um I have a pair of stock similar to yours later model 52 gmc they work great to wake people up.
  18. fnjunk
    fnjunk
    from Australia
    Thanks heaps for the heads up guys going to just run with it on the 12volt system.
    Fnjunk
  19. Slopok
    Slopok
    They will be twice as loud half as long.:D
