Technical 6 volt starter
Discussion in 'Traditional Hot Rods' started by kip's32, Oct 23, 2013.
  1. kip's32
    kip's32
    Does anyone know what will happen if I reverse the polarity on my '54 Chrysler hemi's starter and use it with a negative ground ??
  2. e1956v
    e1956v
    Alliance Vendor
    Starters don't care and will work either way. You will have to replace your voltage regulator and re-polarize your generator. Hope this helps.
  3. Hnstray
    Hnstray
    from Quincy, IL
    Yes, it will work just as well as it did before.
  4. The only thing that will happen is that your starter will turn over faster.
  5. seb fontana
    seb fontana
    from ct
    Why??
  6. e1956v
    e1956v
    Alliance Vendor
    Naw
  7. manyolcars
    manyolcars
    How could that be? You dont have more amps.
  8. kip's32
    kip's32
    Thanks for the info guys !!
    P.S.
    Mine will spin faster as I plan to use the 6V starter with a 12V system
    Kip
  9. Hnstray
    Hnstray
    from Quincy, IL
    38fordpickup is clairvoyant !!!!!!!!!! :eek: :D
  10. 40FordGuy
    40FordGuy
    Faster cranking never hurt !!
    4TTRUK
