Projects 60 chevy wagon tailgate window motor
Discussion in 'The Hokey Ass Message Board' started by marcx3, May 10, 2017.
  1. marcx3
    marcx3
    from phoenix
    Hello I haven't been here in a while I hope every one is doing well and building their dream machine.. anyways, I want it to ask if anybody know is theres a way to use another tailgate or door window motor fr a different year that might fit my 1960 Chevy wagon tailgate?
    lothiandon1940 likes this.
  2. DDDenny
    Many later model vehicles like Blazers, Suburbans, etc have pretty compact cable drive mechanisms, this allows more flexibility for mounting the drive motor. At one time I had considered using one on my 66 Suburban but too much work considering they originally had a fixed window.
  3. marcx3
    marcx3
    from phoenix
    I read somewhere that u can use later model window motor but I don't remember if it was the left or ride side that fit and up to what year, I can use to fit the tailgate!! My car is a 60 Chevy wagon kingswood!!
  4. Daddy_O
    Daddy_O
    Chevrolet Blazer's......full size 70's models....rear window motor/or manual mechanism and arms were same, (or damn near the same), as the early Chevy wagons. I had a '66 Chevelle wagon and replaced worn out rear window motor with one from a '72 Blazer. Pretty sure all the 70's Blazers used the same mechanism as the stationwagons, (early 60's, mid/late 60's). You might want to do some research to be sure......Google is your friend.
  5. 1pickup
    1pickup
    The rear window motor on my '63 BelAir wasn't working, so I took it to a local electric motor shop. They took it apart & cleaned it up. Said it looked pretty good inside. It works fine now. But, Make sure your safety switch is also working. It's on the side of the tailgate. Only allows the window to operate in the tailgate closed position. So, you can't roll the window up, then close the gate, thus breaking the window. It's really just making a ground for the motor. Mine was junk, so I byp***ed it by running the ground wire to the gate itself. Not really recommended, but it was a no cost temporary fix, until I can find a switch. Just something to check out, before you replace your motor.
  6. slowmotion
    slowmotion
    Probably adapt (or just bolt in) a newer model motor as mentioned. When I get a chance I'll dig out my old Hollander and see what I can find out. Don't remember if it goes back to '60, but it's close.
  7. marcx3
    marcx3
    from phoenix
    Thank you guys for all the answer I'll let you guys know what works..
  8. Jethro
    Jethro
    I used a 1985 Caprice wagon tailgate window motor on my 60 Brookwood and it bolted in like it was made for it. Bolt holes same, gear same , same same
  9. marcx3
    marcx3
    from phoenix
    Thanks for the "Jethro" I'm gonna look into it
  10. D'Monsta
    D'Monsta
    Did the 1985 Caprice wagon tailgate window motor work for the 1960 Chevy? Mine is a 1960 Pontiac Safari..
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    this is an old thread and marcx3 has not been here since 2018, you are going to have research that one yourself
