60 days till Roundup
Discussion in 'The Hokey Ass Message Board' started by Rusty, Jan 30, 2007.
  1. Rusty
    Rusty
    Well it is 60 days till departure till the Roundup. I got lots of parts ordered, a 9 "hung under the 38. I got tons to do in a short time but I need the parts. How are all the other thrashes going and late minute changes everyone is trying to make for the Roundup?
  2. InDaShop
    InDaShop
    from Houston
    No thrash is like your thrash. But, I'm stressing a bit on mine and dad's ****.
    I got all the exterior, and interior work on the Riviera done on Saturday. I still need to cut and weld up some holes in the "X" frame reroute the exhaust up so I dont drag it off on Congress. So thats simple enough
    Then I plan to have my '58 Pickup bagged and draggin' between now and then, fingers crossed.........
  3. jrb56
    jrb56
    from Buda, TX
    Just want to let all the folks headed our way that I have a shop available in Buda (just South of austin) for any last minute repairs/welding/etc.
    I will post my cell as the time gets closer.
  4. hot rod pro
    hot rod pro
    from spring tx.
    rusty, don't remind me. i am so far behind,the light at the end of the tunnel is just a flicker.:(
    -danny
  5. I WOULD have had a rolling ch***is this weekend, but my left front spindle is locked up. I am putting on another axle and juice brakes, but it would have been nice to roll it out of the garage without a floorjack.
  6. Kev Nemo
    Kev Nemo
    Hmmm-
    well my 350 should be getting here from City Motor Supply in SA today. Dropping the wounded Snow Blind off at Crushproof to do the heart transplant. I also have some buffing/wet sanding to do here and there. Since SB is my daily, I have an added incentive to get finished PDQ-more like 7 days 'til I need to drive to San Marcos!:eek:
    My old 235 is going to my neighbor and he's putting it into an old 50's a-bodied centerdrive dirt tracker that he plans on having ready by Roundup, so I'll probably help with that as well.
    Late nights, many beers, war stories, bench racing, Black Sabbath and Dixie Witch up loud...
    sounds like fun!:D
  7. extremist
    extremist
    My "thrashes" compared to some of you guys are really more like mild wiggles, but last year I really was thrashing... and I was two f*ing months late for the RoundUp. Chalk up to over-optimism and inexperience.
    This year, all I'm doing to my ford before the roundup is:
    new transmission/converter, cooler, shifter and radiator
    Haven't got any parts yet.
  8. Stu
    Stu
    I'm sure I've going to jinx myself but I started about a week ago hamming on my A project in hopes of getting it just to move on it's on power,as much as I hate to,I'll just trailer it to Austin
    still need to
    1.mount F-100 st.box,st.column,drag link
    2.decided to run tie rod in front or behind axle and mount
    3.come up with a brake pedal/master cylnder and mount
    4.re-do front & rear brakes and run brake lines
    5.mount gas tank and run brake lines
    6.mount battery and run battery cables
    7.mount radiator
    8.wire starter
    9.build headers
    10.convert rearend to open drive
    11.driveshaft
  9. aussiesteve
    aussiesteve
    Rusty
    No thrash this year.I have to get the flywheel balanced on the coupe and other than new old hubcaps,the coupe will look the same.
    Look forward to seeing you all there.
  10. InDaShop
    InDaShop
    from Houston
    Steve where you going to be picking up a dragonfly this year? That lil fellas last year had the time of his life, he was grinning from ear to ear?
  11. hotrodladycrusr
    hotrodladycrusr
    My plan ticket is bought ....that's about the extent of my thrash.:D
  12. bigken
    bigken
    Rusty, my "thrash" goal is 'MOKAN' H.A.M.B. Drags.............
    You wouldn't have a spare steering column around, would ya? :)
  13. great....thats 60 days for me to win the UK lottery so i can afford to come over for it........i can dream
    monkey
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    What?...you takin' medicine or somethin'?...don't remind me. I hate pressure.
    kidcampbell71 likes this.
  15. Rusty
    Rusty
    You better wave at everyone with Hamb shirtswhen you pull in, in the 3w
  16. Saoutlaws_Gotti
    Saoutlaws_Gotti
    60 Days well thats plenty of time but my fear is not enuff paychecks between now and then
    lol
    gotta
    1 Adjust valve backlash and ****om up top of motor
    2 paint and install starter
    3 wire starter, get coil and hookup, wire lights, get brakelight switch and install & wire ignition system
    4 plumb the brakes
    5 fab up fuel tank & plumb the fuel from tank to engine
    6 order tail lights, fab taillight bracket & wire
    7 run lines for trans cooler
    8 order $ 100 worth of front brake line parts & Plumb
    9 Gl*** Trans hump and driveshaft tunnel
    10 Order gas pedal and fab brackets and carb pull cable
    11 install some sort of latches in the doors (easy 5 min job)
    12 get license plates
    13 cut rear white walls
    14 (almost forgot) Get tie rod and drag link made
    15 order and install headers
    oh and im sure theres alot of lil tiny odds and ends im forgetting but im fairly sure the sedan will be at roundup
    and i promise it will be driven not trailered (unless something happens in route of co****)
  17. Saoutlaws_Gotti
    Saoutlaws_Gotti
    I wanna HAMB shirt
    where can i get one
  18. daddyo54
    daddyo54
    from Denison Tx
    Waiting on a flakey sandblaster.
  19. aussiesteve
    aussiesteve
    this year I,ll be followed by some tree hugging,hemp wearing hippies driving a Volkswagon bus just to make sure that I don,t kill anymore local wildlife!!!
  20. Anderson
    Anderson
    Waiting on parts and watching paint dry. Should be done in plenty of time.
  21. speedaddict
    speedaddict
    from Austin, Tx
    man...we haven't even started...thanks for the wakeup call
  22. SwitchBlade327
    SwitchBlade327
    Hopefully I'll get to come out there. If so I'll be thrashing on someone elses ride!
  23. Dirty2
    Dirty2
    Well "Cynthia" has been a real "*****" !! She took the name change ok and the heart transplant but the clean up on the axle went south and the rear of the frame is crackrd but she is still gonna make it.. Now Roco and Cheaters wheres Rustys motor mounts ????
  24. Faded Love Garage
    Faded Love Garage
    from Spring, TX
    All the guys here at Crushproof helped me out in getting the new 400 in. New wheels are next. Install my bumpers and I'm done.
  25. rixrex
    rixrex
    Got a part time job just so I could finish stuff on time..get Dynamat,stereo, seatbelts and interior back in the Studebaker, new starter in the Edsel, get the 34 Chevy up here from San Antonio..
  26. El Caballo
    El Caballo
    from Houston TX
    I'm crying over here, The Roundup is the best show/event we have going with regards to static displays, beer, music, beer. There ain't gonna be one here, but lots of vintage Padmini Premiers running around.
    All of those who can go, need to go.
  27. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    I only have 3 cars to put motors in-not counting the 2 I personally own.
    2 paint jobs... a ch***is to re-***emble...I'm sure there's more, but I am too busy to remember.
    and all the same time, I have to build a paint shop.-in the last 4 months, we have expanded an additional 2000 square feet, hired 3 guys on full time (we're looking for more) and doubled our production schedule. we are growing too fast for me to keep up, it seems.
    oh well, better to be too busy than not busy enough!:)
  28. Skotz
    Skotz
    Rusty,
    My entry fee is sent in, the Flathead 3w is raring to go to the Roundup(for the first time in 3 years, I'm not killing myself getting it ready!!!).....but to make up for it.....my present thrash is on the 5w, getting ready to make the 32 Party on the Left Coast. I guess if it were not for deadlines, nothing would get done in my world:D !!!
    Skot
  29. Big Tony
    Big Tony
    Hell Rusty if you quit working on other peoples rides maybe you could get yours done... Hehehehehe See ya saturday to pick up my ride from and Thanks for taking time to begin my thrash.
    Now i need my motor done
    ****** done
    interior done
    door and trunk gaskets
    window channeling
    wiring harness put in
    wheels re-done
    buy ww tires
    paint top of car
    and most importantly
    work out the bugs and drive to Austin
  30. PBRmeASAP
    PBRmeASAP
    Brake and clutch pedals are in, seat readjusted.....
