'60 Impala master cylinder swap
Discussion in 'The Hokey Ass Message Board' started by skipperman, Mar 8, 2005.
  1. skipperman
    skipperman
    '60 Impala with stock POWER brakes .... Want to change from a single chamber to a dual chamber master cylinder ...... What bolts in ?? Part # or what car would it come from ? Thanks in advance ...........
    Jersey Skip
  2. THOM
    THOM
    i did this to my 59 last year....
    i used a 1968 impala master cylinder, make sure you specify a front drum car, cuz they also had an option for front discs.....
    i think it might be wagner p/n f64885
    the master bolted right up to the booster.......
    the brake line outlets are a little bigger, but thats what adapters are for.....
    -THOM
  3. skipperman
    skipperman
    Thom ...thanks man ... I'll do just that ... the HAMB comes thru AGAIN !!
    Jersey Skip
  4. squirrel
    the main differences between drum/drum and drum/disk master cylinders are the the disk brakes require a much larger reservior, most have one big and one small one. Also many drum only cylinders have residual pressure valves built in...most disk brake cars came with a combination valve instead.
  5. OLDSKEWL61
    OLDSKEWL61
    i used a 67ish catalina master on my 61 caddy with 4 wheel drum dual res. bolted right in.
