60 kingswood wagon......meet helen
Discussion in 'The Hokey Ass Message Board' started by ryno, May 14, 2010.
  1. ls1wagon
    ls1wagon
    from dallas
    Damn man it is turning out great I never relized how different the 9 paa cars were what does the Gas tank look like in that car. Did you move the rear back? I had to in my car to lay on the frame.
  2. ryno
    ryno
    yes i moved the rear end back 1 " to center the wheels better.
    the gas tanks are completely different. ill try and get a pic if i remember.
  3. ls1wagon
    ls1wagon
    from dallas
    Man I would love to convert mine too a 9 pass
  4. ryno
    ryno
    do a search here. there is someone doing a brookwood to kingswood conversion. i don't remember who it was or the thread, but know i saw it.
  5. Cody Walls
    Cody Walls
    Hey ryno and ls1wagon im the one doing the 9 pass conversion , btw your car is so bad ass , im glad to see some one else is taking the time and laying these wagon on the ground the right way , i han't goten that far on my project to really deal with the rear end setup and laying the rear of my wagon on the ground yet but i think your the first one i actually see do 9 passanger , and trying to keep everything , since i have the rear floor section for the 9 passanger on mine and its not installed yet i was just going to notch and get everything set up the put the floor sectiong in a higher location to accomadate the rear frame mods. aney ways keep up the great work .
  6. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Damn you do nice work. This is going to be a sweeeet ride. Gary
  7. RetroSpeed
    RetroSpeed
    Helen has definitely come a long way in a short period of time.
    Congratulations on an an outstanding ride.
  8. A 31 MO FO
    A 31 MO FO
    from D/FW
    Dam Ryno you are a madman. Car is looking good, will it be done for piston & paint in Denton?
  9. 193257
    193257
    Ryan
    Wagon is lookin gooood. Keep up the good work.
  10. billys54
    billys54
    Looks great so far!
  11. ryno
    ryno
    the only problem with doing it that way is your 3 rd row seat back will be way to high, opposed to the other seat tops.
    thanks gary.
    ha i wish man. shooting for the round up.
    thanks. if all goes as planned ill be following you down south again come April!
  12. Cody Walls
    Cody Walls
    Ryno thanks, i totally didnt even think of that , im so wraped up in everything else with the build it totally blew my mind .
  13. ryno
    ryno
    I've been still working on getting it all the way down, think i finally reached my goal!
    frame planted on earth
    got my rear shock mounts fab'd.
    i had to move the transmission x member back 3" to use a 700r4. the floor tunnel had to cut out also to clear the transmission housings. I sectioned the stock x-member down to fit inside the stock mounts that where moved rearward.
    the drive shaft had to be shorted in the front and lengthen in the back. this set up is obliviously temporary. i just needed to get a idea of the angles that the shaft will be at to clearance the x frame top in the rear. allot of frame, about 10" or so had to be cut out and raised to clear the shaft angles. a slip joint will have to be used for the extreme push/pull with billet center support bearing.
    mounted up the cpp 7" dual booster and vette sytle mc. had good clearance from my stock valve covers.
  14. ryno
    ryno
    i still need to snap a shot of the tank its self, but the under cavity looks like this.
  15. Malcolm
    Malcolm
    from Nebraska
    Holy shit... that thing looks killer sitting on the ground! Nice work, Ryno!
  16. tcb-1
    tcb-1
  17. ryno
    ryno
    thanks nick.
    hows the roadster coming?
    thanks
  18. benchseat4speed
    benchseat4speed
    from Golden, CO
    SIIIICK!! Keep at it!!! I'm subscribed now.....
  19. 193257
    193257
    Now that is a ground Hugger
  20. Man that's gonna be bad ass. Can't wait to see it finished. I love wagons. Subscribed.
  21. Rusty
    Rusty
  22. I can't wait to see this thing finished! It's gonna be sweet!
  23. ryno
    ryno
    thanks fellas
    i had to raise up the top of the x-frame to clear the drive shaft.
    ill post some pics later, left the camera in the shop!
  24. ryno
    ryno
    i shaved the firewall. removed the heater core, fan box, factory wire looms, and a bunch of unnecessary holes and divits.
    started the body work to smooth it all out
    i shaved the factory radio,center speaker, heater controls, ash tray, light switch hole and wiper holes.
  25. ryno
    ryno
    go the transmission tunnel and drive shaft tunnels fab'ed up and welded into place.
  26. Gonna be a sweet waggin when all is done. Nice work ryno.
  27. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    Lookin great man!
    Change your mind on the dash?
  28. ryno
    ryno
    still not too sure. wanted to get the profile of it like this before cutting into it more.
  29. hartmankustomz
    hartmankustomz
    Looking great Ryno....gotta come by and check it out.
  30. Bit of a late question, But did you have any problems getting the front quaters of?
    I'm having troubles getting my front left quater off, due to a rusted out bolt at the bottom of the panel, But before the cowel, Inside the seal i think.
