Greetings, all I'm having trouble with the current column in the wife's Bonneville. It has the turn signal switch mounted about where modern columns have the neutral safety switch (and actually looks like one) and this is what's dealing me misery. I'm considering just putting in a later model tilt column and was wondering if anyone out there has done this. If so, what column did you use, etc. Any help is appreciated.
Wow, that might be tough. I'm sure it's do-able, but consider the rag-joint (steering coupler), Turn signal switch and the neutral safety switch. Good luck, also what's the issue with original column? Ken
i have a complete 64 catalina column shift tilt unit with steering wheel $350+shipping retread46@comcast.net
