60" rear end to wide
Discussion in 'The Hokey Ass Message Board' started by jacoviii, Mar 12, 2009.
  1. jacoviii
    jacoviii
    is a 60" wide rear end to wide for a 49 shoebox
    it is a 8.8
  2. Johnny1290
    Johnny1290
  3. Cirilian
    Cirilian
  4. 19Fordy
    19Fordy
  5. jacoviii
    jacoviii
    the 60" is to the out side total
  6. 19Fordy
    19Fordy
    Still to wide. For instance, a 49-51 Merc rear is 61 1/4 in. total from wheel mounting surface to wheel mounting surface.
  7. dumprat
    dumprat
    from b.c.
    I am running an 8.8 out of an explorer. I used two short side axles to narrow it. It ends up being 56.625 wide. The original is 57
  8. dirt t
    dirt t
    I have a mavrick rear end PM me. I don't know where your located.
  9. So what's the Shoebox rear axle width?
    About 56" drum flange to drum flange?
    Strikes me that a wheel with an additional 2" backspacing over the stock wheels may do it.
    We used to stick 8.20-x15 (Caddy) tires in the stock wheel wells on Shoeboxes, but it was a tight fit.
    Almost always the drivers side was close and it would rub on a hard left turn.
    Cured by cutting part of the fender opening flange into segments and bending it up parallel to the quarter panel skin for an additional 1/2" - 1" clearance.
    I understand the 57 1/2" wide 9" rears fit pretty well.
  10. jacoviii
    jacoviii
    ok how about a 1978 monarch
    it had a 351w and c4
    think it would work
