Projects 60's 1932 3W Build
Discussion in 'The Hokey Ass Message Board' started by hotrodfab32, Jun 1, 2018.
  1. Bandit Billy
    Bandit Billy
    A trip across the buffer and I'd say you have something there!
  2. hotrodfab32
    hotrodfab32
    It wouldn’t take much but there’s not going to be much shine on this car - just clean and simple.
  3. Mike Colemire
    Mike Colemire
    With fab work like this, you don't need no shine!
    hotrodfab32, loudbang and hendelec like this.
  4. RatPwrd
    RatPwrd
    LOL that beautiful fab work is anything but simple!
    hotrodfab32 and loudbang like this.
  5. lodaddyo
    lodaddyo
    clean and simple?? i think we are p***ed simple. beautiful fabrication and welding skills!
    40FORDPU, hotrodfab32 and loudbang like this.
  6. oldsman41
    oldsman41
    Wow I could go on and on but wow sums it up.
  7. hotrodfab32
    hotrodfab32
    Well ****.
    I’ll at least try to keep it clean.
    Thanks for all the comments
  8. AHotRod
    AHotRod
    Beautiful insight and craftsmanship... is a bona fide Hot Rod.
  9. thintin
    thintin
    Can't be enough hours in the day!! most excellent.
  10. hotrodfab32
    hotrodfab32
    Started on the column next. Want to keep it small so the tube is 1-3/8 and the top housing is only 2-3/8 dia. It uses a large sealed ball bearing. Several angles being cut here to get the shape then will blend everything.
    The hub is a 3/4-16 spline coupling shortened and welded to some round stock. It is held on by 3/8-24 flat head bolt that threads into a tapped hole in the end of the shaft.
    A shouldered sleeve was made that the bearing fits on and welded to the splined shaft. When the hub is bolted on it seats against the bearing to hold the inner race. A coupling will be welded to the other end to mate up with the steering box.
    Bearing is held in the housing with a snap ring.
    A ****on will be made to fit in the counterbore over the bolt and center the steering wheel. Like everything else the bore in the housing for the tube was small and it was heated up to install the tube.
    The tube is long and will be shortened when it is fitted with the seat and wheel. Just the steering wheel left then everything can be mounted.
    catdad49, hendelec, GordonC and 11 others like this.
  11. hotrodfab32
    hotrodfab32
  12. hotrodfab32
    hotrodfab32
    To make a steering wheel a piece of 7/8 x .156 wall tubing was rolled into a 15-1/2 OD hoop.
    Then it was cut and welded. It will be powder coated semigloss black.
    The spokes were drawn and water jet cut from 3/16" 316 SS. 1/4" pieces were welded to the ends so 10-32 flat heads could be countersunk flush to attach it to the hoop.
    Spokes were laid out on the hoop then pockets were milled. 1/4" pieces were welded flush then milled flat.
    The spokes were clamped in place and holes transferred to pads.
    Wheel installed with steering box mocked up.
  13. big duece
    big duece
    from kansas
    Outta site man...!
    rod1, enloe and loudbang like this.
  14. loudbang
    Leave it brushed silver to match the dash. :rolleyes:
    enloe and brady1929 like this.
  15. dave agosti
    dave agosti
    I covered mine in a leather kit for steering wheels.
  16. hotrodfab32
    hotrodfab32
    Wanted it to look like a hard rubber wheel but nothing in stone
  17. 30tudor
    30tudor
    Outstanding fabrication skills throughout this thread. A pleasure to read.
  18. DDDenny
    And the photos are eye candy!
    hendelec and brady1929 like this.
  19. hotrodfab32
    hotrodfab32
    Thanks guys
  20. slug
    slug
    A few folks like you on the HAMB just make me feel like my work is pretty shabby. It's the kind of work I wish I could do. Thanks for the motivation.
  21. cfmvw
    cfmvw
    Gotta love CAD! I've always used Solidworks for a variety of projects, even used it to design the p***ive solar home that I built.
    rod1, Just Gary and loudbang like this.
  22. 2deuces64
    2deuces64
    Like others have said WOW. I also learned I'm a hack
  23. @hotrodfab32 I hope you didn't mention it and I over looked it, but why did you use a spacer in the exhaust bracket, looks *****in', I just wanted to be educated on it.
  24. hotrodfab32
    hotrodfab32
    Sway bar link bushings will be used for vibration. Spacers that are the same height as a compressed bushing are used while fabricating to locate things more accurately and they don't melt when tacking.
  25. OK, makes perfect sense! Thank you.
    hendelec and loudbang like this.
  26. Magfiend
    Magfiend
    Amazing build - this kind of quality is a real inspiration for those of us who don't have the same skills and knowledge.
    hotrodfab32, loudbang and Kelly Burns like this.
  27. hotrodfab32
    hotrodfab32
    Thanks. It's the guys that knock this stuff out day after day and can make a living at it are the ones that impress me.
    To mount the box a 3/16" base plate was made that fit against the floor. Holes were drilled to clear rivets and spacers welded to the bottom . Body bolts are used to fasten it and the spacers make sure its tight against the frame and not just the floor.
    To attach it to the door pillar a 1/4" plate with 3 drilled and tapped holes was made that goes inside the the pillar. An angled bracket bolts through the pillar into the 1/4" plate so the pillar is sandwiched between them. Its stronger than welding tabs and if I don't like the steering its easy to take out.
    A piece of aluminum was used to make a pattern and figure the bend angle. I want to be able to put carpet and a kick panel in without them sticking out. The body bolts will be flat heads. The vertical plate was cut out of 3/16". 2 more pieces tie into the firewall leg. A shim was used to account for floorboard thickness.
    To add strength to the top front corner, a lip was added between the firewall tabs and extended on up. Flanges for the box were cut from 3/16". The mount was slotted and holes drilled in it.
    A gusset was added in the corner. A piece of 2" tubing was used in place of the steering box when mocking everything up. With the box tacked in and everything tight it seemed to turn pretty easy even sitting still with no flex in the mounts. About 3-1/2 turns at the wheel. I won't weld the flanges until the column height is checked again after its chopped and seat height determined.
    rod1, lucky ink, neilswheels and 17 others like this.
  28. panhead_pete
    panhead_pete
    Outstanding and mind blowing. Thanks so much for sharing!
  29. loudbang likes this.
  30. 40FORDPU
    40FORDPU
    Skills combined with the vision..what's not to like?
    Impressed, this car is a stand out.
    Thanks for posting your project.
