Has anyone ever used the common 60s Chevrolet truck master cylinder( brakes and clutch master) as a dual master cylinder just for brakes specifically drum front and rear? Thanks
somebody talked about that here a long while ago. A balance bar from pedal to both bores. I'm not sure what the design of the bar needs to be, to be able work ok if one side fails if a hose pops. But you need to add a stock residual valve & it's round black rubber washer, in the clutch bore, same one as in the brake side. .
Thanks to both of you, never thought of the residual valve but couldn't we simply use one in line? Safety is of course a major concern always, we are trying to get away from the 1964 master cylinder on this old hot rod and replace it with a better/safer system. If it wasn't on the firewall it wouldn't be all that important. A big, ugly Mustang cylinder just seems wrong as does a pair of new Wilwoods. Thanks again.
