and i noticed that I still had the temporary rubber bushing at the bottom of my collumn so I pulled it out
I took the collumn to the local old car parts store they couldn't help me and sent me to the local cl***ic car parts dealer who couldn't help me and sent me to the local muscle car parts guys who at least identified my collumn for me. turns out my $25.00 keyless shiftless tilt is out of a '67 Camaro of all things My question is; what other collumns shared the same plastic bushing and metal clip that goes at the bottom of the collumn and where can I get one?? or should I just ebay this damn thing and grab something a little less hoity ****in toity?? Paul
I think I'd make my next stop at the chevy dealer. I'll betcha that bushing interchanges for a few years and the parts guy should be able to fix ya up.....maybe.
Rocky is right-but I bet fullsize GM columns are the same for a few years- probably 1965 to maybe 70 or 72. At least Pontiac ,Olds, Chev, or Buick. Camaro tilt columns are worth about 10 times what you paid for it. That polish job is the "cat's ***"!! overspray
thanks guys, I just got back from the dealer I bought the only one available, fits '69 thru '75 tilts unfortunately I was unable to make it fit mine. but I think I have a solution, at least temporarily a pvc coupling has the exact outside and inside dimensions to center the bearing in the collumn jacket. this is all the original was doing. Paul
I'll put a screw in it to make sure it stays put, but this should work till I find the correct part. Paul
try looking at 68-69 Novas. cant remember if they had the key on the column or not, but that generation Novas ganked from the first-gen Camaro parts bin all the time. dan
'67 Camero? I'd try NAPA. I'm out today anyway so I'll drop by the local and get them to look it up for me. '67 is no longer a dealer part so you should be able to get a bushing from anyone that knows how to use the Book instead of the computer that only goes back about 10 years or so.
thanks porkn******, I will keep up the hunt too, my temp bushing will be plenty good to get it all back together but I don't want to leave it in there permanantly.. I expect to be doing better than a hunnert per in just over a month and it's gotta be right, if ya know what i mean Paul
'60s I understand completely. Somehow the wind just has a taste @ 100+. I'll be headed out the door toot-sweet for my morning break. Drop you a note as soon as I get in.
paul that col. looks identical to the caddy tilt tele's that i run.. I cant believe that they had diff diameters.. but who knows.. I bet NAPA should have one... good luck sawzall
porkn******, see if you can make sense of this sketch the shaded part is the plastic bushing I made, it centers the ball bearing that centers the shaft in the inner and outer housings. this is basically all the original plastic retainer did. if I use a generic bearing to take the place of the bushing and bearing it needs to fit the shaft and outer housing but I still need to center the inner housing. maybe with another bushing between the two housings.. I think I should still try to find the original plastic retainer. I will look at all late sixties GM columns. it may end up being a junkyard item. Paul
