60's F100 question
Discussion in 'The Hokey Ass Message Board' started by TORR, Nov 13, 2011.
  1. TORR
    TORR
    from BOSTON, MA
    Does anyone know the first gear ratio in a stock F100 3 speed tranny?
    Specifics- 1961 6cyl.
    Thanks.
  2. TORR
    TORR
    from BOSTON, MA
  3. If you know the model of the trans, this site may help.
  4. TORR
    TORR
    from BOSTON, MA
    No luck on that site, my trans reads:
    Tag on case: HEF F 025114
    Cast onto case: C3AR 7006-E
    And: C3TR 7A040 W-2
    Anyone know any other websites?
  5. Try this one, it is old, but may have the info. They mention this tranny having either a 2.59 or 2.79 first gear.
  6. stuart in mn
    stuart in mn
    I think the C3 in the numbers you found indicate the transmission was built in 1963, so the original was replaced at some point.
    As far as the ratios go, my 1966 truck manual says the light duty 3 speed transmission had a 2.99 first, 1.75 second and 1.00 third in trucks with a 240ci six engine. I don't know for sure, but chances are the ratios were the same for 1961-1966 trucks - my parts catalog shows in 1966 the tag would have read HEF-xx (the xx = various letters depending on the exact model truck.)
    edit: there was one version in 1966 that had ratios of 2.79, 1.70 and 1.00, but it was only used in the Econoline with a 170ci six.
  7. TORR
    TORR
    from BOSTON, MA
    FAUJ,
    Thank you very much, that answers my question.
    I appreciate the help.
  8. Mattilac
    Mattilac
    Yo Torr,
    You can measure the ratio too just to be sure. Put it in gear and spin the rear shaft 1 turn, and see how many turns the front shaft spins.
