Technical 60's GM throttle rod to Edelbrock bushing
Discussion in 'The Hokey Ass Message Board' started by Vetteman61, May 4, 2023.
  1. Vetteman61
    Vetteman61
    from Tennessee
    What grommet/nylon bushing are you guys using to connect 60's GM throttle rods to a newer edelbrock? The hole is too big for the stock rubber grommet?
  2. 325w
    325w
    Elebrock
    has one in a package by it self
    scotty t and hemihotrod66 like this.
  3. pprather
    pprather
    egads likes this.
  4. Bob Lowry
    Bob Lowry
    Advance auto and others....
    2OLD2FAST, jimmy six, Paul and 2 others like this.
  5. Vetteman61
    Vetteman61
    from Tennessee
    I haven't found one on the Edelbrock webpage.
    thanks pprather. I had seen that one show up before, but I hadn't seen the reviews that indicate it does fit an Edelbrock. It seems that that is the solution I was lookin for.
    Bob, the rubber bushing you posted appears to be the stock one that would work on the linkage at the firewall, but is too small for the edelbrock.
  6. larry k
    larry k
    I just tack weld a 1//4”- 20 nut in the hole , then use 1/4” heim joint !!!
    jimmy six likes this.
  7. Paul
    Paul
    Editor
    like the Moroso linked to above
    here is Summit's version:
  8. Vetteman61
    Vetteman61
    from Tennessee
    I ordered the Moroso one and it ended up being too thick to allow my cotter pin to go through the hole. As it turns out, the stock GM one does fit the 1/2 hold in the Edelbrock, even though many folks online say it didn't.
    2OLD2FAST and 427 sleeper like this.
  9. Mitchell Rish
    Mitchell Rish
    from Houston MS
    If you have a bench grinder or small hand grinder tou can thin it if but chance you still wanted to use the moroso. Just a thought.
