61 biscayne and a saginaw
Discussion in 'The Hokey Ass Message Board' started by tobacco_barn, Sep 25, 2012.
  1. tobacco_barn
    tobacco_barn
    Does anyone know if an early GM Saginaw 4speed will line up pretty easy in a 61 Biscayne with a 3 speed as far as length and mounting trans mount or will I need to do some mods?
  2. fab32
    fab32
    Should be a bolt in with the exception of the hole in the floor for the shifter.
    Frank
  3. tobacco_barn
    tobacco_barn
    Thank you very much for your wisdom.
  4. tobacco_barn
    tobacco_barn
    how about the driveshaft length ?
  5. B.A.KING
    B.A.KING
    might check the length of the trans. my 59 had the little bitty 3 speed. when i put the saginaw 4 in, had to shorten the ds.
  6. squirrel
    The driveshaft will probably have to be shortened and you'd need a fine spline yoke.
  7. 56sedandelivery
    56sedandelivery
    Since you have to shorten the shaft anyway, now might be a good time to go with a one piece shaft. Butch/56sedandelivery.
  8. bobss396
    bobss396
    I did a similar swap in my '65 Belair, only with an early Muncie M21. Took out the same ****py 3-speed box that yours has. The lengths were the same, the only thing I recall is making the hole in the floor and maybe a front driveshaft yoke swap.
    Bob
  9. oldolds
    oldolds
    If you still have that short 3 speed. You will need to get a 4 speed drive shaft, or shorten yours. You will also nee correct yoke. You might need to get a different speedo cable as well.
  10. the front driveshaft yoke is same as the finer splined one for a 350 Turbo trans.....Ditto on the one peice driveshaft idea......
    A driveshaft from a 1978 Delta 88 Olds is about right,and is a smaller diameter than most....
    you would need an"adapter" U joint at rear as the '61 takes a smaller joint at the pinion....
  11. squirrel
    or shop around for a driveshaft that is the right length and uses the 1310 ujoint so it will just bolt in.
