61 falcon 289 or inline 6
Discussion in 'The Hokey Ass Message Board' started by sylverxrs, Feb 22, 2010.
  1. sylverxrs
    sylverxrs
    from merced
    I have a 61 falcon and contemplating upgrading the factory 144 to either a 289 or a bigger inline.
    What do you guys think???
  2. davidwilson
    davidwilson
    from Tennessee
    289 - use factory parts to install it
  3. need louvers ?
    need louvers ?
    do a later 200 and t-5 combo
  4. 69fury
    69fury
    427 SOHC, with a 8-71 over a solid axle.
  5. ironandsteele
    ironandsteele
    350 chevy
    (kidding, kidding)
  6. sylverxrs
    sylverxrs
    from merced
    ha ha ha
  7. I'll second that!
  8. sylverxrs
    sylverxrs
    from merced
    maybe on the next one.
  9. Undercover Customs
    Undercover Customs
  10. sylverxrs
    sylverxrs
    from merced
    thats what i am leaning towards but a lot of people are talking about inline.
  11. Kustom Komet
    Kustom Komet
    V8s are faster, period. But a proper Falcon V8 conversion includes the front suspension, brakes, steering, and rear end in addition to the engine and trans. The skinny four lug stuff is just not up to the abuse unless you drive it like a grandma on smooth streets. Figure all of this into the 289 swap.
    If you go with a 200 six, it'll bolt in and even with a few mods, it will be safe and fine with stock suspension/rear end. And a good 200 is a fun little motor to drive, torquey and more than enough to keep up with modern traffic. This is obviously the least expensive way to go.
    -KK
  12. sylverxrs
    sylverxrs
    from merced
    not sure if i will ever make up my mind. i just might get both. 200 first and then get the 289 and pick up everything as i go, then when i have everything for the 289 swap it again. your never finished anyway.
  13. in high school my bud built a 200 6 with a 4brl nad it would out torque most small blocks he went up against.
    and you dont have to do the front end
  14. sylverxrs
    sylverxrs
    from merced
    i kinda like the way that the inline sounds, for some odd reason
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    Try this on Google search:turbocharged Ford Falcon, great story covered in several online magazines.
  16. duste01
    duste01
    just a side note to add in. Once upon a time, Dad's 63 comet had an oil delivery problem in his 200. Working at the local auto parts store, I discovered that the first year mustang 250 has the same bell housing pattern as the 140, 160, 200,220. So Dad's s-22 comet has a 250 in it with no mods. It keeps up with everything, and gets good mileage.
  17. xafalcongs
    xafalcongs
    Do a late model big bellhousing 200 with a T5 and swap on the alloy Classic Inlines cylinder head. Great head and with a small 390 4bbl or a 500 2bbl, you'll be pushing 200hp from that little motor.
  18. newfalconowner
    newfalconowner
    from NS Canada
    or a plain 390 over a MII suspension
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Before you decide you mat want to go to www.fordsix.com and check out some very cool inline rides.
  20. 300 Ford six. Will make a 289 look sick. (or a 302 even)
    fun fast and furious. And no Bubbas It is not 20 feet long. Most sixes are with in an inch or so a a v8. (The V8 pump has extra length to fit in the 6 cyl hole. The difference often compensated for by the length of the water pump. Parts are plentiful , power is huge and it will bring crowds at every cruise in.
    DonD
    "The Peppermill" was a famous 60s Falcon with a 300 six.
  21. sylverxrs
    sylverxrs
    from merced
    Think it's going to be 289
  22. mart3406
    mart3406
    from Canada
    What about a built 300 inch truck six, with a single 4-bbl or two-2-bbls and a T5 5 speed???? That could be cool!
    Mart3406
  23. Ford-Man
    Ford-Man
    I am (unless I sell my Comet) going with an inline 6, small 4bbl, split header and true dual exhaust. Pretty much stock engine with maybe a cam and some mild head work depending on the cost vs. a new head. That is...unless I can sell it first. I battled with putting my mild 289 in my '61 and putting the 390 in the truck, but I like my 289 to much to put it in something I would rather sell.
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Look for a V8 Maverick or Comet---you would end up using several pieces from it for your conversion, and it would be cheaper than buying everything you need piece by piece.
  25. Used Up Junk
    Used Up Junk
    from Merced, CA
    sylverxrs, sorry I have been meening to shoot you a PM for a few days now. I'm a friend of Cacey's and our buddy Drew told me to look up your post. I swapped out the 200 in my mustang for a 302 so I know how to do the swap and what needs to be changed as well at what you can keep (in a Mustang at least). If you have any questions shoot me a PM on here. Let me know what you need for parts too I have a bunch of Ford stuff at the shop. Later, Roger
  26. weez
    weez
    I've heard you have to custom fit a later bigger six, (Like in the Giulmet/Bade Ranchero) and the 289 is a bolt-in.
  27. davis574ord
    davis574ord
    Keep the six they are cool good mileage plenty of poop!
  28. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    I say stay with the inliner!
