Projects 61 Falcon - Father Son Project
Discussion in 'The Hokey Ass Message Board' started by blown240, Oct 21, 2021.
  1. D Newcomb
    D Newcomb
    I have a '60 Falcon ex race car- they are under-rated as to their promise of fun, and quite light weight. Favorite blue too. My Dad hated cars-had to do it all on my own. Newc
    Joe Travers and loudbang like this.
  2. TrailerTrashToo
    TrailerTrashToo
    Two separate electrical systems.
    1. If your stock Falcon used an instrument panel voltage regulator (reduces 12 Volts to approximately 6 Volts - the 6 Volt stock gauges were not redesigned for 12 Volts), you still need an instrument panel voltage regulator. The exception is if you replace the stock gauges with 12 Volt aftermarket gauges.
    2. The internally regulated alternator charges the battery - the electrical system remains 12 Volts.
    Russ
  3. blown240
    blown240
    from So-cal
    Thanks Russ! That makes sense.
  4. blown240
    blown240
    from So-cal
    Friday was a very productive day!
    We got the instrument cluster all wired up. I didn't like the stock wiring that had 1 light for both turn signals, and 1 light for the high beam indicator. So we wired it to have 2 turn signal indicators, and we are using the voltage idiot light as the high beam indicator. I'll have to figure out a new label for the light. We will be using a Voltage gauge instead of the light.
    I promise that all these wires got zip tied into a nice clean harness... IMG_4893.jpeg
    We tested the gauges with a 3v source, and they all work. When we tested the voltage reducer, it had the same voltage on both sides, so we got a new one. The new one does also has the same voltage on both sides when tested. So maybe the old one wasn't bad, but we got a new one either way.
    Next up, we tackled the steering column. It was a pain, but we got it together.
    We ended up having a part left over. Im pretty sure its the turn signal cancel lever, but I am not really sure where it goes, or how it works.
    Also, There is a gap behind the steering wheel. Do we just need to tighten it more? (I'll 3d print a shift indicator needle at some point...)
    This is where we ended up for the day. Does anyone have a suggestion for a horn ****on? From what I understand we can use any ford town ****on ***embly until 74. I also could really use a good exploded view of the horn ****on and how it works.
    Next up we need to hook up the turn signal wires under the dash, then it will be time to fire it up, and let it warm up. Then we need to get some junkyard parts for the power brake conversion.
    brEad, GordonC, loudbang and 2 others like this.
  5. I believe the stock horn ****on also has a horn ring. Mine was sticking so I tore it off. I wonder if that's common.
    Bill Whitehurst and loudbang like this.
  6. blown240
    blown240
    from So-cal
    Ya, there is a horn ring stock. I dont really see a need to spend close to $90 on a new one when a standard horn will work fine.
  7. Also quoting the questions, "Does anyone have a suggestion for a horn ****on? From what I understand we can use any ford town ****on ***embly until 74. I also could really use a good exploded view of the horn ****on and how it works."
    This isn't exactly what you're asking for, but maybe it gets things closer. I don't know what you mean by 'town' in "any ford town ****on ***embly until 74."
    Hmmm, my 61 Ranchero has a horn ****on without a ring.
    Thor1 likes this.
  8. fiftyv8
    fiftyv8
    from CO & WA
    Have you considered doing that Karel Shelby front suspension modification???
  9. connielu
    connielu
    That wheel and ring are pretty common, they were used on pickups and fairlanes I believe. You Ford guys correct me if Im wrong.
    My last project was a 1962 Falcon Futura, found it in a garage in Woodbridge Ca. Very solid as it had set inside for a great while. Great little cars for youngsters to start with. A m#$?#$g three core radiator will fit if you move the brackets on the tanks slightly (unsolder and resolder)
    Have fun!
    loudbang and Thor1 like this.
  10. blown240
    blown240
    from So-cal
    Thanks for the replies!
    Sorry. The word TOWN should be HORN. I must have misspelled it and the computer changed it to town.
    Ya we will do the Shelby drop once we can drive it and see if there are any other steering or suspension parts needed.
    loudbang, fiftyv8 and Thor1 like this.
  11. gimpyshotrods
    gimpyshotrods
    Bronco, as well. Both available as reproductions.
  12. fiftyv8
    fiftyv8
    from CO & WA
    When I had my Falcon with the Shelby drop, I was always trying to figure out how I could use a steering rack rather than the old original setup.
    Even a power rack if turning got too heavy.
    I have a shoulder injury that is always a concern for me...
  13. gimpyshotrods
    gimpyshotrods
    I have a Borgeson power box in my Falcon.
    It took some fab to get it in, but it works great.
    loudbang and fiftyv8 like this.
  14. LWEL9226
    LWEL9226
    from So. Oregon
    Has anyone tried the (O/T) Prius electric power steering on these Falcons????
    LynnW
    fiftyv8 likes this.
  15. blown240
    blown240
    from So-cal
    is the power steering 12v or part of the high voltage hybrid system?
  16. gimpyshotrods
    gimpyshotrods
    For clarity, I will respond to my own comment.
    The box bolted right in, as did the pump. Easy peasy.
    The fab part was the bottom of the column, and the u-joint.
    On the round body Falcons the coupling point is half inside, and half outside the firewall.
    My solution was to use a u-joint instead of the rag joint, and to build a column reciever and mount, out of a chunk of column sleeve and a clamp. It has access holes to get to the upper set screw and lock nut.
  17. blown240
    blown240
    from So-cal
    Quick post...
    The gas cap on this car is a bit of an eyesore. Locking caps in general aren't great looking. BUT, seeing as how a teenage boy will be driving this, and it's a FALCON, I 3D printed this gas cap cover. My son LOVES it...
    The hole in the center is for the key to take the gas cap off. Ill get some pics of it on the car the next time we are up there.
  18. goldmountain
    goldmountain
    Now that's a great gas cap.
  19. fiftyv8
    fiftyv8
    from CO & WA
    I also shortened my column about 2" as I hated having the wheel so close up to my chest.
    That was a great improvement for me and my seat position.
  20. blown240
    blown240
    from So-cal
    Thanks for the replies! I am very interested in the electric power steering… when we get to that point….
  21. LWEL9226
    LWEL9226
    from So. Oregon
    12 volt I believe....
    LynnW
  22. LWEL9226
    LWEL9226
    from So. Oregon
    We are having the same problems on a 1956 Ford Parklane Wagon....
    LynnW
  23. gimpyshotrods
    gimpyshotrods
    I will take some pictures of the column in the car and PM them to you.
    I have a leftover column, in what I think is the same diameter tube, that I could donate a chunk to help you along.
    TrailerTrashToo likes this.
  24. LWEL9226
    LWEL9226
    from So. Oregon
    I would like to have some pictures.... Thank You....
    LynnW
  25. Georelle
    Georelle
    That left over part is the turn signal cancel. It just clips on the bottom of the steering wheel. It can be a bit of a tight fit but that is what you want.
    LWEL9226, Thor1, loudbang and 2 others like this.
  26. blown240
    blown240
    from So-cal
    Great! Thanks!
    warhorseracing likes this.
  27. blown240
    blown240
    from So-cal
    we only had the chrome for the trunk emblem... So back to the 3D printer for an insert. This will go along nicely with the gas cap cover...
    IMG_4995.jpeg 66517267594__754A9D03-83DC-496B-AD85-C37178A93740.jpeg IMG_4991.jpeg
    I will likely reprint this emblem at some point to clean it up a little, but for now, he is super happy with it!
    I hope to have some time this week to ****on up all the wiring, Then we will be ready to do the Geo Metro power brake conversion, and hopefully get to drive it for the first time!
    Tickety Boo, brEad, Jimmy and 5 others like this.
  28. blown240
    blown240
    from So-cal
    We got a lot done on Monday... The wiring is 99% done, and everything seems to work like it should with the exception of 1 bulb socket. We also installed an aftermarket 3 gauge set, and now we can see that the car is charging at 14 volts.
    The gas cap cover and trunk badge turned out great too!
    The next step is the brakes. I am going to get new wheel cylinders, brake hoses, shoes and hardware. I'll have the drums turned if need be.
    Are steel braided brake lines that much better? Or is it all looks? We are adding power brakes, so if the stock style hoses aren't sufficient, ill get steel braided...
  29. blown240
    blown240
    from So-cal
    Do you guys think I should use steel braided brake lines, or are rubber lines fine with power brakes?
  30. gimpyshotrods
    gimpyshotrods
    Rubber lines are fine, so long as they are fresh, and from a good vendor.
    Thor1 and loudbang like this.
