61 Falcon lowering question.
Discussion in 'The Hokey Ass Message Board' started by solo_909, Sep 24, 2009.
  1. vw505
    vw505
    from Lemoore,CA
  2. vw505
    vw505
    from Lemoore,CA
    not realy much to it.
  3. newfalconowner
    newfalconowner
    from NS Canada
    its possible to modify one for the 6, but a v8 one wont fit a 6 out of the box..
  4. newfalconowner
    newfalconowner
    from NS Canada
  5. solo_909
    solo_909
    Why do you need one of those bars?
  6. newfalconowner
    newfalconowner
    from NS Canada
    it keeps the lower towers/frame from flexing, just like the top bar does on top.. stiffens up the front subframe.
    Bill Whitehurst likes this.
  7. fiftyv8
    fiftyv8
    from CO & WA
    Take our advice and install one of those bars it will be worth it.
    The front in these falcons is too flexible without it and surely will help make it a little safer if things go wrong.
  8. solo_909
    solo_909
    sounds good ill look into it. So does anyone have any idea what size Ubolts the 61 has? I want to make sure I get the right parts. Thanks
  9. newfalconowner
    newfalconowner
    from NS Canada
    i cant remember what they are, my ubolts are long gone. take a 7/16th open end wrench and stick it aorund the ubolt, if it fits good then its 7/16, or try 3/8 or whatever. then measure from the top of the axle down the the end, theres the length, then add 2in. Just make sure theres at least a full nut on the ubolt, extra is better and you can trim excess.
    what master cylinder do you have too?? since your going thru all that, change to a 67 mustang dual bowl master cylinder and make some new lines. theres lots of help online to swap a dual bowl master in falcons.
    iif you blow a line, you will have NO brakes with a single bowl (fruit jar master), with a dual bowl, least you will have some braking because its all split up front and back. The single bowl feeds all brakes.
  10. newfalconowner
    newfalconowner
    from NS Canada
    lowering the upper arms wont drop it what you want, lower the arms and cut 1-1/2 coils out.
    as for alot of work for not much change, that is wrong. It will correct your steering and handling alot.. but the choice is yours.. cutting the coils only is ok too.
  11. BlackEsDime
    BlackEsDime
    The lower tie bar you're talking about, do they not come with one? I was just looking at my '61 and there is a bar that's bolted between the lower control arm under the oil pan.
  12. newfalconowner
    newfalconowner
    from NS Canada
    the bar were talking about bolts to the lower part of the shock towers where the motor mounts bolts too. :)
  13. need louvers ?
    need louvers ?
    I'm just reading this thread for the first time and I have to say that both of my '62's have the tube tie bar on them. Both are six powered as well. I do Know that the Falcon went through several ch***is changes during the first part of 1962, so maybe this was one of them. Could be a 1960 only thing as well, ( no bar ).
  14. BlackEsDime
    BlackEsDime
    Thanks, thats that i was thinking, just wanted to double check. My '61 has one. (170 CI)
  15. Notorious Nick
    Notorious Nick
    Your car has been one of my inspirations.
  16. gimpyshotrods
    gimpyshotrods
    My '60 has the bar. It left the San Jose/Milpitas plant with it.
    My buddy Mark's dad worked the line there, and likely built my car. He says they ALL got them.
  17. gimpyshotrods
    gimpyshotrods
    HELL NO!
    The purpose of this mod is NOT to lower the car. It is to create a negative camber curve on hard cornering, which was a design defect.
    My '60 has alarming adhesion in corners. Yours can too, if you can manage to drill 4 holes.
  18. Fingers
    Fingers
    +1 The Shelby drop really changes the way they drive
  19. jtripp
    jtripp
    Where did you guys find the lowering block and u bolts at for a 61 falcon ?
  20. The Svenmeister
    The Svenmeister
  21. The Svenmeister
    The Svenmeister
    What type of air shocks do you use? Are they lower stroke?
