Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. brianf31
    brianf31
    I'll let you know how they ride - late next year if I can get it finished!
    Big Dad, bchctybob, Deuces and 17 others like this.
  2. b-body-bob
    b-body-bob
    That looks closer than a year away to me
  3. brianf31
    brianf31
    The schedule is purely budget-driven:D
    Just Gary, Thor1, b-body-bob and 2 others like this.
  4. bchctybob
    bchctybob
    I just read through the whole thread, nice work and outstanding results. It’s really taking shape, I can’t wait to see the engine go in and see it driving.
    Makes me miss my ‘60 Falcon.
    brianf31, loudbang and lumpy 63 like this.
  5. brianf31
    brianf31
    Thanks! I hope to get the engine to the machine shop in the next month or so. I still need a few short block parts.
    bobss396 likes this.
  6. brianf31
    brianf31
    Continuing the aircraft theme with some dimpled seat risers in .090 aluminum.
    I'll fasten the seat with quick release pins for access the rear seat area. seat riser.jpg
    Deuces, -Brent-, bchctybob and 7 others like this.
  7. 69fury
    69fury
    from Topeka
    just found your build, great stuff! Definitely an inspiration to get to work on mine. How far back did you move your firewall?
    Thanks,
    Rick
    brianf31 likes this.
  8. brianf31
    brianf31
    Thanks! I moved the firewall back about 8". It's 6" from the axle to #1 spark pug so that the block is completely behind the axle.
  9. 69fury
    69fury
    from Topeka
    That's really close give or take where my 414inch small block mopar is located and ive been stumped trying to figure out how to do a firewall and throttle pedal when the exhaust port is 8" closer to me than my foot- i dont see room for a header tube unless i remove the toe boards as well. i've lately given up on that setback and been thinking of moving the mill back up to the engine bay and putting a firewall back in (and for the first time being envious of ford front mounted distributors). I'm no tin bender or experienced fabricator. I like your ladder frame additions-I slid 2x3" box section into the front subframes, and think i might add some more ladders to the rockers like you did.
    Thanks!
    -Rick
  10. brianf31
    brianf31
    Gen
    Generic advice: put the engine where you want it, remove the firewall and toeboard if you must, move the seat and steering back if needed and fill in sheet metal from there. The sheet metal is the easy part. Sketch it up on paper before you cut!
  11. brianf31
    brianf31
    Things are about to get real. I dropped off the valve covers and timing cover to the machine shop for vapor honing. I talked to them about short block machine work while I was there. I should drop it off soon.
    I threw together a cradle for transport. I needed something other than an engine stand to index the bellhousing anyway.
    brEad, -Brent-, bchctybob and 5 others like this.
  12. brianf31
    brianf31
    Dad rough-lettered the hood scoop. Black border will sharpen it up. I'll get him over here to letter the rest when the weather warms.
    Deuces, JalopyJimbo, -Brent- and 8 others like this.
  13. brianf31
    brianf31
  14. RmK57
    RmK57
    Going to do the stroker thing?
  15. brianf31
    brianf31
    Nah, I'm just doing a .040" over 460. It will be enough to break parts.
    Deuces, brEad, -Brent- and 3 others like this.
  16. loveoftiki
    loveoftiki
    from Livonia,Mi
    That awesome…hope to see it moving under its own power by summer haha
    Deuces and brianf31 like this.
  17. brianf31
    brianf31
    I hope so! I've been selling a lot of old parts lying around to generate some funds.
    bchctybob, loudbang and loveoftiki like this.
  18. bobss396
    bobss396
    We did a 460 with a stroker kit for a '72 Torino stock car.... I think it was a 496 when it was done. Much more than being able to break parts. Even the milder 429 was a stump puller with 10:1 compression and a mild "cheater" cam. That is the whole beauty of the 429/460 platform.
  19. brianf31
    brianf31
    Oh yes. No replacement for displacement!
  20. bobss396
    bobss396
    The stroker was a PAW kit, we had a sponsor spring for it somehow. We outfit the garage like an operating tent, no joke. My partner had sheets tacked up on the ceiling and all around the ***embly area. We HAD to wear clean clothes.
    It lasted about 4 races and then it blew... people still talk about it that were there. My brother was running my Nova right behind him and emerged out of the blue oil cloud. He wound up 3rd or 4th.
  21. brianf31
    brianf31
    I dropped off the block at the machine shop. They do top-notch work decking, boring and line honing with CNC equipment. They have state-of-the-art balancing equipment but for some reason, they don't turn cranks.
    This crank looks to be in decent shape but it did have 20+ years of surface rust. I gave it the old sandpaper and shoelace treatment.
    bchctybob, Deuces, brEad and 5 others like this.
  22. RmK57
    RmK57
    Those old cast 460 cranks are good for 750-800 hp before you need to start thinking about 4-bolt mains.
    Cleaned up quite nice, a polish and you might be good to go.
    Deuces, loudbang and brianf31 like this.
  23. SS327
    SS327
    What the heck is vapor honing? Why would you do it to valve covers and t chain cover?
  24. aussie57wag
    aussie57wag
    from australia
    I'd love to build one of them with a blown y-block. Very cool car.
  25. brianf31
    brianf31
    It's wet media blasting, aka wet blasting. It's effective for removing oxidation, paint and grime.
    Deuces and SS327 like this.
  26. brianf31
    brianf31
    That would be sweet!
  27. brianf31
    brianf31
    Yep. I sanded with 800, 1000 and 1500 grit before buffing with Blue Magic polish and a microfiber towel. The shine ain't there yet. I think I'll go back with some 2000 grit and then trying Br***o.
  28. brianf31
    brianf31
    Dad came by to mock up the lettering. It was good to have him hang out in the shop. We'll paint when the weather warms a bit.
    We'll add "Fort Valley, Ga." in 1" lettering under the gas cap.
    I'm still thinking Georgia Cracker on the quarters.
    Deuces, brEad, bchctybob and 8 others like this.
  29. brianf31
    brianf31
    The ol' oven cleaner trick didn't work that well for removing the faded anodizing on the grille and headlight rings. After a lot of sanding and buffing, I got it good enough for a drag car.
    Deuces, GordonC, JalopyJimbo and 6 others like this.
  30. brianf31
    brianf31
    I'm converting the small input, small output toploader to a big in, big out for use behind the big block. Dan Williams Toploaders makes and supplies some nice parts.
    Deuces, GordonC, brEad and 7 others like this.
