Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. brianf31
    brianf31
    The one thing that makes my '31 coupe unpleasant to drive is the small radiator. It will reach 210 deg cruising in warm weather and goes upward in heavy traffic. I didn't want to deal with that on the Falcon.
    I got the biggest radiator I could fit; it's a 4-row Champion with a 16" X 24" core. It's wide enough that I had to put it forward of the steering box. Behind that is two Spal high performance 11" fans.
    With all the engine setback, I would have needed a 2 foot-long radiator hose! I'm not sure I could have found one to fit. Instead, I extended some Afco radiator tubes to fit. It kinda looks like a Flathead install, or maybe a tractor trailer:D
  2. RmK57
    RmK57
    You have an extra couple quarts of coolant through the extensions so in my opinion that’s a good thing.
  3. Chadthesailor
    Chadthesailor
    So I have to ask, when using housing floaters like this what do you do with the alignment pin on the leaf springs? I have a 62 Falcon thats about to get the same treatment.
  4. brianf31
    brianf31
    Some guys use monoleaf springs.
    In my case, the housing floater "roller" is behind the pin on '65-'73 Mustang leaf springs. I moved the axle back one inch to allow more room for the fender radius cut.
  5. brianf31
    brianf31
  6. Chadthesailor
    Chadthesailor
    Ah okay thank you, just seen the video fired up! Killer man!
    brianf31 likes this.
  7. Big Dad
    Big Dad
    I like everything about it , except my name not being on ***le .. good job
    deathrowdave, bobss396 and brianf31 like this.
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
    Hell you’ll be driving it way sooner then ya thought
  9. brianf31
    brianf31
    It depends how much redneck engineering I'll tolerate:D Mainly I need to hard-wire everything, re-do the trans tunnel and add seatbelts.
    bchctybob, JalopyJimbo and Thor1 like this.
  10. brianf31
    brianf31
    3" Porter mufflers are installed. Removing 4 bolts per side will allow it to be dropped for track duty. I'm planning on painting the exhaust flat black.
    bchctybob, GordonC, Outback and 9 others like this.
  11. deathrowdave
    deathrowdave
    from NKy
    Stand tall and be proud ! She’s top shelf
    brianf31 and loudbang like this.
  12. Take us along on the first drive!!! Please!!!
    Such a cool car!!!!
    loudbang and brianf31 like this.
  13. 6sally6
    6sally6
    0001X.jpg TWO THUMBS up fer sure!!!!!
    6sally6
    Outback, loudbang and brianf31 like this.
  14. brianf31
    brianf31
  15. brianf31
    brianf31
    Obligatory HAMB Alliance firewall tag. I'll have to get the two lower rivets when I pull the headers for repaint.
  16. brianf31
    brianf31
    This thing was running very rich. After the test drive, I pulled the plugs and they were black as coal. I figured that would happen. I had to turn the idle screw in to get a decent idle, which in turn exposed the transfer slots and pulled in too much fuel. Idle air screw adjustment with a vacuum gage didn't help. Some will drill holes in the ****erflies to lean up the idle.
    Since I'm not a great carb tuner, I sent it off to Big's Performance in Altoona, WI. Those guys take your carb, specs and goals and will ship back a custom , bolt-on-and-go calibrated carb. I'll tackle other details while I wait.
    Flat black VHT paint made the mufflers and pipes disappear pretty well.
    I added some harness but still need to put in the submarine belts and seat braces. I think I'll cut off those goofy belt brand name labels if I can get to the s***ches without damaging the belt.
    Next I'll try some vinyl cleaner on the nasty seats.
    bchctybob, brEad, lumpy 63 and 6 others like this.
  17. AmishMike
    AmishMike
    Do it cut off any seat belt info needed to certify the belts. But sure u know that
  18. brianf31
    brianf31
    Yep I won't touch the date/cert labels just the logo.
  19. duecesteve
    duecesteve
    Black magic marker the emblems?
  20. SS327
    SS327
    Mr Clean magic eraser or soft scrub and a scrub brush.
    brEad and brianf31 like this.
  21. bobss396
    bobss396
    Tuff Stuff upholstery cleaner is good on vinyl.
    deathrowdave and brianf31 like this.
  22. duecesteve
    duecesteve
    That came out really nice its a cool car! :)
  23. Outback
    Outback
    from NE Vic, Oz
    That is as cool as a cool thing, I love Falcon's!
  24. Thanks for the ride. And as expected it, is as cool as it looks.
  25. 6sally6
    6sally6
    From one Ga Cracker to another...... Thx for the ride along !
    Please tell me you worked some magic in the distrib with light springs and (possibly advance limiter) !
    The distrib when set up right will allow a LOT more adjustment of the carb. Lightening quick advance of timing and total advance around 36* seems to be the ticket for hot rods....
    6sally6
  26. brianf31
    brianf31
    I haven't mapped out the timing curve yet. I pulled the carb and sent it off for calibration since it was idling so rich. As soon as the carb is back next week, I'll play with distributor timing.
    I had it on 12 degrees initial. These Kaase heads are very efficient and like somewhere between 28-30 degrees total, all in by 3000 rpm. I'm running a Pertronix distributor and my last Pertronix had 20 degrees mechanical advance. I'll likely have to change advance springs and add limiters to get it where I want it.
    bchctybob, brEad and bobss396 like this.
  27. brianf31
    brianf31
    I like to run vintage parts on my old cars when I can. I wanted to use an old beer can for a radiator overflow tank as hot rodders have done forever. I found a 70's Pabst can on ebay and noticed the address said Pabst, GA. It turns out that when Pabst built the plant east of Perry, GA (about 30 minutes from where I live) in 1970, they created so many jobs that Perry temporarily renamed the town Pabst, GA. The plant sold and became something else in 1983. Anyway, local nostalgia is best nostalgia!
    53 effie, bchctybob, SS327 and 5 others like this.
  28. Mmmmm…. PBR…. Or as we call it around here, “HangOver in a Can”!
  29. bobss396
    bobss396
    I buy it quite often, mainly in the bigger cans. Now and then I run across it in 24 ounce.
  30. Honest officer, I only had a couple beers…..
    SS327, brEad and bobss396 like this.
