This car originally from Texas and already had a very clean body and floor to start with. The body is painted factory Ermine white with a black insert stripe. The body is nice and straight. New custom interior was done by Sullivan upholstery in New London Ohio and looks great. This car is a fresh build and driven approx 500 miles this past summer in 2016. Engine is a very healthy 331 with alum canfield heads and lunati roller setup and muncie 4 speed with ****tershield. Car has a healthy lumpy idle thru the flowmaster 44 exhaust and looks the part sitting on the drag radials. Have had many people ask if it was a 409 or BBC car when pulling into a show.. This car runs, drives, rides and sounds great. CPP Power steering and 3.36 gears makes it a pleasure to drive. Asking $45k.. This is a nice 61 and mostly everything on this car is new. Too many new parts to list.. PM me if you have serious interest.
Some specs on the car.. Body: Texas body, solid floor/trunk pans and sheetmetal Ermine White base/clear Restored Original grille Bumpers rechromed and look great Side mouldings and trunk mouldings were replaced with reproduction pieces from Hubbard’s Original EZ eye blue/green tinted gl*** All stainless window trim was restored Engine: Originally: 283/PG Now: 327 +.030 (331) Keith Black domed pistons (10.5:1 runs pump gas) Lunati Solid roller camshaft with Crane 1.6:1 aluminum Roller rockers makes .560” lift with .030/.030 lash Aluminum Canfield heads with 2.08 intake valves / 220cc intake runners Dual plane Air gap intake ported to match heads Summit billet distributor (MSD) Summit 650 duel feed carb Engine was painted chevy orange and disguised as a factory 283 Trans/Rear: Muncie aluminum 4 speed Lakewood blow proof bellhousing Hurst compe***ion plus shifter Ram Powergrip performance clutch Lightweight 15# nodular flywheel Factory rearend 3.36 gears Wheels/Tires/brakes: Front - 55 Chevy 15x5 wheels with 205/75 radials Rear – Wheel Vintiques 15x8 OE style steel wheels with 275/60 drag radials 2” dropped spindles with lowered springs and Slotted rotor disc brakes. Rear has lowered coils with drum brakes CPP power steering box and Alan Grove pump brackets New control arm bushings New ball joints New dual master cylinder and prop valve by cpp Exhaust: Ported Corvette 2.5” Ram horn manifolds Dual stainless mandrel bent exhaust Flowmaster super 44 mufflers Interior: Custom black / white vinyl with French s***ching done by Sullivan Upholstery. Black carpet and dashboard Trunk was repainted with factory style splatter paint
