Projects 61 lesabre vs 61 impala differences
Discussion in 'The Hokey Ass Message Board' started by Donuts & Peelouts, Nov 7, 2019.
  1. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    With both cars drive train gutted, how similar are these two cars.
    I'm guessing they both are on the improved x frame ch***is.
    The Buick was know for great breaks, how about the Chevy?
    Suspension? /interchange?
    Rears?/ interchange?
    Drive shaft?
    When ordering parts for the Buick what can I order as a Chevy, and what cant I?
    Front suspension?
    Windshield?
    Is their a good parts interchange website someone could tell me about?
    I think that's all folks but I might have more questions?
  2. squirrel
    Windshield is the only part you mentioned that would interchange.
  3. Taboo56Chevy
    Taboo56Chevy
    Pretty much nothing will interchange between the two without a lot of work, very few things (if any) will just bolt right up. The front and rear window and trim is probably the only things that will swap. The thing to remember about GM in the 60's and older is that every brand was a sperate en***y with blinders on. It wasn't really till the late 60's when stuff started to be swapped between the brands.
    Donuts & Peelouts likes this.
  4. stuart in mn
    stuart in mn
    As mentioned, each GM division back then had their own ch***is, suspension and drivetrain. Window gl*** and some minor odd end ends like door lock push****ons will interchange but that's about it.
  5. squirrel
    Interchangeability got it's big start with the 1964 midsize GM cars. This ain't one of them.
  6. Texas Webb
    Texas Webb
    I liked the differences in the late '50s to '60s before every thing started to look the same.
    Donuts & Peelouts and Frankie47 like this.
  7. Squablow
    Squablow
    As mentioned, totally different frames and suspensions, no drivetrain interchange at all. But they are based on the same basic body shell, some lowrider guys will use a LeSabre convertible to convert an Impala and that works, also I've seen plenty of '61 Buick 2 door hardtop roofs get swapped onto '62 Impala box tops to make bubbletops, that also works. Window regulators and most gl*** interchange, some other stuff like that.
    lewk and Donuts & Peelouts like this.
  8. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Ok thanks guys. I thought they had the same ch***is for sure.
  9. Taboo56Chevy
    Taboo56Chevy
    they look close and probably the bare rails might be the same but once brackets were added then its different between the two brands.
  10. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thats what I was thinking. So grinding off the Buick brackets for the rear and welding Chevy brackets could get me more parts availability theoretically?
  11. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Wow , I didn't know buble tops could be made
  12. Probably could use an Olds or Pontiac roof too.
    Or actually a 1961 Chevy 2 dr. hardtop also. ;-)
    Pontiacs used a perimeter frame from 61 on. Not sure about Buicks but quite possible.
    Edit : It appears that Buick used an X-frame until 1964..Still nothing would be the same as Chevys
  13. jimmy six
    jimmy six
    61's were "only" tops.
  14. squirrel
    the frames don't look the same to me.
  15. saltflats
    saltflats
    from Missouri
  16. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    saltflats likes this.
